Alternative starter motor for the NA
Martijnus
PostPosted: Fri Jul 10, 2009 2:57 am    Post subject: Alternative starter motor for the NA Reply with quote
Inspired by the gear reduction starter group buy and some problems with my own starter I took a dive in the pool of starters.
I'm getting confused.
PET list says:
059 911 023 F for the 924
035 911 023 N for the 924 with automatic gearbox.
Google search on the first number gave me this information:
http://www.teilesuche24.de/ersatzteile/anlasser-starter,bosch_986010110
with this pic:
The things I'm confused about at that moment:
9 teeth correct?
The turning direction seems correct, don't know how to see that...is that CCW or CW?
The info on 924.org ( http://www.924.org/parts/parts.htm ) says it has 9 teeth but turns CW. I believe it's CCW.
After another search I've found this starter:
http://www.teilesuche24.de/ersatzteile/anlasser-starter,hella_8ea726047001?c=100359
The info says it should fit the 035 911 023 F, and this IS a gear reduction starter. The only difference is that the flange is 82mm instead of 83mm (see above)
looks good.
Has 9 teeth and turns CCW (in german that's "Drehrichtung im Uhrzeigersinn")
So far so good, this looks like the one I need.
Hmm. I wanted to create this topic because I thought I found an alternative with the 'correct' part no... but that had 13 teeth. Can't find it anymore so I guess I was mentally unwell or something...
Does that hella one look good?
The bosch alternative (with correct porsche/vw numbers!) is this one:
http://www.teilesuche24.de/ersatzteile/anlasser-starter,bosch_1108026
the only difference is the angle of the relay, but I don't know if it's a gear reduction starter. It sure is expensive
I guess that hella one is the one I need.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Fri Jul 10, 2009 3:13 am    Post subject: Reply with quote
Hallo Martinjus,
CCW stands for Counter Clock Wise right ? In german that means
Gegen den Uhrzeigersinn.
And CW means Im Uhrzeigersinn.
As for the starters, i only new about the 0,9 KW and 1,1 Kw diffrence.
But i have seen a new typ of starter installed in a NA 924. It was a thin tube style outlay, with half of the thickness of the original ones....
Dont now the brand..no pic.
Martijnus
PostPosted: Fri Jul 10, 2009 3:29 am    Post subject: Reply with quote
Nobbi wrote:
Hallo Martinjus,
I just babelfished that german part and you're right! It is CW instead of CCW. So apparently it's CW. I've checked the hella catalogue and as far as I can see the only difference is the flange (0.5mm difference).
The new-type starter you mention is a gear reduction starter, the one I want
this is another pic of the hella I've posted above:
compared with the 'old style' hella:
edit: funny how you keep typing martinjus instead of martijnus doesn't matter but coincidentally I thought about that this afternoon
if someone knows some examples of replacement voltage regulators, please let me know
RC
PostPosted: Fri Jul 10, 2009 3:52 am    Post subject: Reply with quote
IIRC the 4 & 5 speed NA starters are rated at 0.8KW while auto ones are 1.0KW. Was listed in Bosch & Rock Auto catalogs, not disputing Nobby`s figures, very similar anyway.
Standard Bosch or aftermarket replacement.
Pick your voltage depending on battery:
http://www.holcombedirect.com/search.htm?searchterm=1+197+311+021&searchmode=all&s_category=18&oper=lt&searchprice=&DoSearch=Show+Matches&numresults=10&viewfrom=1&step=2
Martijnus
PostPosted: Fri Jul 10, 2009 7:07 am    Post subject: Reply with quote
thanks! are those plug&play or something? Checked the pet list and I couldn't find a seperate regulator on the pics.
Oh could be 13 on p 354. 070 903 803A, is the bosch 1 197 311 090
aren't these the ones then?
http://www.holcombedirect.com/search.htm?searchterm=1+197+311+090&searchmode=all&s_category=18&oper=lt&searchprice=&DoSearch=Show+Matches&numresults=10&viewfrom=1&step=2
PostPosted: Fri Jul 10, 2009 11:10 am    Post subject: Reply with quote
Just to clarify, NAs require a CLOCKWISE rotation on the starter...
Martijnus
PostPosted: Sat Jul 11, 2009 12:38 am    Post subject: Reply with quote
I ordered the starter today. Tomorrow I'll pick it up at the shop. It'll be a bosch one iirc so we'll see. the part no. is the 0 001 108 026.
v8carreragts
PostPosted: Sat Jul 11, 2009 1:33 am    Post subject: Reply with quote
In case anyone is interested this is the starter I had used in my 924's.
(Postal Jeep starter)
http://cgi.ebay.com/ebaymotors/POSTAL-MAIL-JEEP-STARTER-DJ5-G-MODEL-121-CID-REMAN_W0QQcmdZViewItemQQ_trkparmsZQ7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem413f7fc0feQQitemZ280238211326QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
RC
PostPosted: Sat Jul 11, 2009 2:06 am    Post subject: Reply with quote
Yes Martijnus looks like you`re correct about the regs. Stock one was similar IIRC and see difference is the diameter of slip ring. Think the ones I linked to fit later models, 944 anyway. My alt is a rebuilt higher current bitza (bits of this & bits of that).
So is that Bosch starter you ordered a reduction drive? Interested to hear more and see some pics of it.
Martijnus
PostPosted: Sat Jul 11, 2009 8:34 am    Post subject: Reply with quote
i'll post that stuff when I've got it raceboy supplied a number in the group buy thread, but that number seems to be unknown to suppliers outside russia or something like that
It should be a gear reduction starter. I asked for the hella starter, and the guy searched on the bosch number I supplied. He found it, and I said I wasn't sure if it's a gear reduction starter, and he responded that it sure was. If it isn't, he just isn't getting any money from me... simple as that. I want gear reduction, I get gear reduction.
Anyway...it's for the audi 90 types so it should be gear reduction.
I'm excited the last few days... I think it's a great improvement on my car.
The price on the links above is more than 400 eur, but the price including taxes etc would be 190 eur for me could be it's a rebuilt one or something... as long as it works fine it's all good. Have to make a trade with my old starter... but he only gets the old one when the new one is fitted and working properly.
Martijnus
PostPosted: Sun Jul 12, 2009 7:53 am    Post subject: Reply with quote
guess what...they didn't deliver the starter motor at the shop today
I drove the car to my work and put it on the car lift to get rid of some things like the old starter etc.
Found out the old starter was literally falling apart, due to the long screws which apparently came loose. Haven't touched them ever, so it's not my fault...but it explains the very bad performance.
Also concluded that my alternator bushings are gone, but I can't find a supplier for new ones. I'm really getting pissed off about those car material suppliers. They're such stupid and ignorant people... the only thing they can do is find the parts which belong to a licence number and get them from a shelf. If you supply a vw number, they get confused and kick you out of their protected and simple environment because you're a potential hazard or something.
Anyway.. I'm in doubt between searching for rubber ones or fabricate some out of some plastic material.
also found out all my wheels have play... explains the vibration during braking. The front is easy, the rear will be expensive..and I can't get my fubar'ed drain plug out of my gearbox overtightened by the previous owner I guess... amateur.
monday I'll have the new starter (installed)
Martijnus
PostPosted: Wed Jul 15, 2009 7:16 am    Post subject: Reply with quote
Wow, what a difference.
Picked up the starter yesterday. The starter is slimmer and feels lighter.
It's a rebuilt unit, from a brand I couldn't figure out (= I didn't make the effort to find a brand name), but that all doesn't matter.
It was plug&play, very nice.
With my battery not recharged it still turned the engine as if there weren't any spark plugs in it. Sounded like a modern car starting. Great stuff, I'm really happy with it
part no for reference is Bosch 0 001 108 026.
Harm
PostPosted: Wed Jul 15, 2009 7:52 am    Post subject: Alternative starter motor for the NA Reply with quote
Jeez, how long is that gonna take? …Martijnus, if you are still in need of a starter, PM me your addres and I'll post (DHL/TNT) you my spare one tomorrow morning. You can borrow it for now but do want/need it back for a propper rebuild: bearing is a bit worn; Works fine though! (bench tested)
Hahaha - yeah I recognize that; They are all depending (limited) on the contracts there boss/headoffice setup/contracted whit the Distributer (Grossier). When computer says “No” it means they have the wrong Distributer (with a limited contract) Some times I have to visit vife different shops to get a result. never depand on one car material supplier.
And VW is NOT longer allowed to pass out 924 parts; They no longer have the PET catalog at the components counter (since two years or so?)
Drive south and try Belgium for parts?
The Bosch shops in Germany were a great help for me! Richtig guter Hilfe
Regards, Harm
Edit01: My oldie starter is the fat one.
Edit02: Pfff… you did get it! Nevermind… Enjoy!
Martijnus
PostPosted: Thu Jul 16, 2009 1:59 am    Post subject: Reply with quote
thanks anyway man!
RC
PostPosted: Thu Jul 16, 2009 2:59 am    Post subject: Reply with quote
Excellent job and info.
So obviously it fits and is not any longer? And it is same as these?
http://www.electricalpartsdepot.com/auto/1990-1994--audi-23l-bosch-unit.htm
http://www.electricalpartsdepot.com/auto/1995--audi-22l-bosch-unit.htm
http://store.electricalpartsdepot.com/shared/StoreFront/default.asp?CS=myepd&StoreType=BtoC&Count1=972820460&Count2=889960885&ProductID=178918&Target=products.asp
Or theoretically, any of these alternatives:
http://www.allworldautomotive.com/featured/ebay_detail.php?pfvid=1688&itemid=220282695501
Oh, your car is LHD?
