masterdave
Posted: Wed Jul 08, 2009 7:22 am Post subject: injector seals |
| i have a 924s and i disassembled the fuel rail today as i have been having fuel problems. one of the injector seals is bad and needs to be replaced but the other ones seem fine. Is it worth it to replace all the seals while im at it, they are original. or will it not make a difference? |
moorepower
Joined: 21 Dec 2006 Posts: 263 Location: Raleigh, North Carolina, USA
Posted: Wed Jul 08, 2009 9:09 am Post subject: |
Definitely replace 'em all while you're in there. You can get seal kits at Pep Boys for like $2 each. Very cheap insurance against fuel leaks. _________________ Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways |
masterdave
Posted: Wed Jul 08, 2009 11:05 am Post subject: |
| thanks for the info, they were like 9$ on dcauto.com that is pretty much what i was going to do any way. I've been working on the car all day and its falling apart in front of me due to rust i pretty much have to replace the whole fuel system. |
derg
Posted: Sun Aug 16, 2009 5:41 pm Post subject: Fuel Injectors Sealing Problems |
2.5S engine 1988
We made a kind of in situ external hill of high temp silicone around our injectors even after we had 'em reconditioned. We see this as a safety measure to stop air or fuel leaks. _________________ "there are more stars in the sky than grains of sand on this planet" |
