joemerchant2006
Posted: Thu Jul 02, 2009 3:30 pm Post subject: My Clutch pedal is squeeking. |
| Is that a bad thing? I mean, if I press it down to the floor quickly, it squeeks loudly, but it I do it slowly, it doesn't. Is this a sign of an expensive fix or do I just need to hit it with WD40? |
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Thu Jul 02, 2009 4:46 pm Post subject: |
I think you should start with WD40.  _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
Chrenan
Posted: Fri Jul 03, 2009 12:32 am Post subject: |
Use white lithium grease for lubricating moving parts, not WD-40. _________________ 1987 951 - M193 Version for Japan |
