Removing Waterpump
dash16
PostPosted: Sun Jun 07, 2009 12:17 am    Post subject: Removing Waterpump Reply with quote
gohim wrote:
The waterpump bolts are often very corroded and break off. That means you have to find a way to remove them with damaging the block and rendering it useless.
What is a safe way to do this?
Done with college. Tackling FOES as soon as parts arrive.
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
Ian924s88
PostPosted: Sun Jun 07, 2009 4:11 am    Post subject: Reply with quote
you have to remove the cam belt, balance shaft belts, & back cam belt cover piece to get it out. I was just in there yesterday because the water pump had to be tightened down to the engine ( leaking a bit & sucking in air ). at least I'm hoping thats why it keeps running hot erratically. I have the break down of it all if you need it on a PDF file for the 2.5L engine. My 1988 used an updated pump style with the belt guide on it. Actually heading out to put coolant back in the system.& get all the air out of it.
1988 Blue 924s
John_AZ
PostPosted: Sun Jun 07, 2009 9:36 am    Post subject: Re: Removing Waterpump Reply with quote
dash16 wrote:
"gohim" The waterpump bolts are often very corroded and break off. That means you have to find a way to remove them with damaging the block and rendering it useless.
Here is an answer if it happens.
Take your time and use penetrating oil and maybe it will not be a problem. You can get new WP bolts and nuts in a kit.
Answer:
http://tech.rennlist.com/924_944/brokenwaterpumpBolts.PDF
The gasket needs a sealer-Harbor Freight sells Hylomar which many people use: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97824
Or a Permatex non hardening product.
More WP info:
http://www.arnnworx.com/h2o-pump.htm
And finally Pictures of a FOES job:
http://home.att.net/~porsche944/seals/page.html
GL
John_AZ
1988 924S + 1987 924S
PostPosted: Sun Jun 07, 2009 11:25 am    Post subject: Reply with quote
Of course the best way to avoid corroded and broken waterpump bolts is to replace the waterpump on time, and keep an eye on it, replacing the waterpump as soon as there are any signs that the seals are failing, regardless of the time or miles that the car has been driven since the last waterpump replacement.
The corroded bolt/s are the result of coolant leaking from leaking/failing waterpump seals, and the failure of the car's owner to replace the waterpump at the first sign/s of failure.
dash16
PostPosted: Tue Jun 23, 2009 11:30 am    Post subject: Reply with quote
so getting some liquid wrench onto the nuts of the WP is not a problem but there is no way to get it onto the bolts.
Am I just going to have to get lucky and hope that the bolt doesn't snap while trying to remove it?
STUTTGART PREVAILS
