Torque Tube bearings specs
PostPosted: Wed Jun 24, 2009 10:43 pm    Post subject: Torque Tube bearings specs Reply with quote
Since a lot of the info is currently in a for sale thread that will eventually expire, I'm creating a new thread here so we don't lose the info. Note that the following info is specifically for the NA torque tube:
Andrew NZ wrote:
The bearings are:
6005ZR
ID 25mm
OD 47mm
Width 12mm
UK source for bearings, courtesy of Rich H:
http://simplybearings.co.uk/shop/advanced_search_result.php?categories_id=4475&1_10=125_1&21_210=125_21&22_220=125_22&23_230=125_23&29_290=-1&30_300=-1&31_310=-1&extra_field_filter=1&x=24&y=6
US source for bearings:
http://www.vxb.com/page/bearings/PROD/6005ZZ10-1?gclid=CPzds7X_mpoCFSbxDAodn3-68g
Source for torque tube rebuild kits for 924S/ 931 / 944:
http://www.porschehybrids.com/php/viewtopic.php?f=2&t=3225
Same guy as above on Pelican (with photos):
http://forums.pelicanparts.com/showthread.php?t=468571
Canadian source for 924S / 931 / 944 bearings & inserts:
http://www.jageng.com/garage9/index.php?cPath=49_106
Clark's Garage tutorial on torque tube rebuilding:
http://www.clarks-garage.com/shop-manual/trans-05.htm
924.org info on torque tube rebuilding:
http://www.924.org/techsection/7transaxle.htm#3%20-%20torque%20tube%20rebuild
It would be nice to find a source for reproducing the bearing carriers. Maybe this would be a good thing for Min to work on??? Anybody have a spare they can send him?
