Fuel Pressure regulator question.
legoist
PostPosted: Sun Jun 21, 2009 7:20 am    Post subject: Fuel Pressure regulator question. Reply with quote
Does anyone know if Bosch 0280160227 is interchangeable with
0280160286.
here's the back story:
I have been fighting a intermittent start issue for a while now.
the car will sometimes start and catch right away, usually when it is cold out. It won't stay running when driven for very long, but I can leave it idling for quite a while even if I rev the engine etc...
Other days, both hot and cool, the car just cranks but won't fire.
So far I have done the following:
    I tried removing an injector plug
    jumper-ing the DME relay
    replacing injector seals
    reworked vacuum lines
    replaced check valve
I ave also tried unsuccessfully to measure fuel pressure at the rail. I say unsuccessfully because the only pressure gauge I could get my hands on was a harbor freight model. It would read pressure with pump going but not running around 37 psi
However the gauges, I had two different ones, then stop working all together.
Anyway. One of hte things I tried was swapping the fuel pressure regulator out with one I got with a used Fuel rail. That didn't help either. When I looked at the part numbers on each regulator they were the same. Later I looked the part up and found that he regulator I was using and the one I pulled off were for a 944. the 924s has a different part number.
0280160286. One pats site has the 227 part number as the correct one.
I'm wondering if the different part is causing issues...
Thanks,
Chris
924s - 1987 Not running
RC
PostPosted: Mon Jun 22, 2009 2:01 am    Post subject: Reply with quote
Try googling those part #s + bosch to try find data. AFAIK the early 944 FPRs are 2.5 bar and later 3 bar. Disconnecting the vacuum line will raise pressure sufficiently for a rich start whatever.
However, playing with the fuel system is usually in vain until you`ve checked spark. Sounds like it may be your crank sensor which is a very common problem.
