electrical problems since pulling the speedo cable
dash16
PostPosted: Fri Jul 17, 2009 1:18 am    Post subject: electrical problems since pulling the speedo cable Reply with quote
here are the symptoms:
instrument cluster lights do not work
rear round light and tail lights on when key not even in ignition
I was rough when I pulled the speedo cable out about a year ago; I've learned to be more gentle since then.
all the wires/plugs run the right places behind each gauge so I suspect is somewhere down the line.
Please help me resolve my past sins.
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
edredas
PostPosted: Fri Jul 17, 2009 2:21 am    Post subject: Reply with quote
If you have the fuel gauge cluster out, the under hood light and parking lights will come on when the key is inserted; (perhaps the side markers too, but I don't have any on my car to check...) Also the headlights won't work.
This will also cause the dash gauges to light up if they're grounded... so check the ground and the bulbs...
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
dash16
PostPosted: Fri Jul 17, 2009 3:04 am    Post subject: Reply with quote
the key is not inserted
the dash lights do not work when the key is inserted
headlights work fine.
STUTTGART PREVAILS
PostPosted: Fri Jul 17, 2009 3:45 am    Post subject: Reply with quote
All exterior lights except the headlights (and possibly foglights) should work without the key. Even the turn signals should light (without key), but not blink.
dash16
PostPosted: Fri Jul 17, 2009 4:09 am    Post subject: Reply with quote
yes, but what im saying is that the round rears and tailights REMAIN on.
might be a nightmare or a simple fix.
STUTTGART PREVAILS
edredas
PostPosted: Fri Jul 17, 2009 4:15 am    Post subject: Reply with quote
Sorry, about the last post... I read it really fast and also the lights will work with the gauge out; (it must have been a fluke in the car I was last working on, I just tried it in my car and it works normal...)
Ok, what happens when you turn the parklights on? Do the parklights come on and the side markers go out? Or do they all come on together?
These cars electrics can do very strange things, and most of the time have a very simple fix... so check the fuses and assure that everything is plugged up tight...
dash16
PostPosted: Fri Jul 17, 2009 6:36 pm    Post subject: Reply with quote
turning the parking lights on:
side markers on and the round lights
no dash lights
i really hope i didn't screw something up where i have to pull the dash apart to get my hand in that weeee tiny space
STUTTGART PREVAILS
edredas
PostPosted: Sat Jul 18, 2009 4:24 am    Post subject: Reply with quote
Are the side markers dim when they are on all the time? ...or atleast dimmer than they are when you flip the switch?
If so, it's a grounding issue... try grounding the dash lights somewhere and see if you can get them to work... this may fix you're glowing light problem as well...
