toolboxterrorist
Joined: 13 Mar 2008 Posts: 35 Location: cummington ma
Posted: Tue Jun 09, 2009 1:04 pm Post subject: suspension interchangeable? |
i have a 1980 924 parts car it has good koni struts with weltmiester sp250 springs i just purchased a 85.5 944 and one of the front struts is blown what i want to know is can i put the 924 koni's in my 944 and not have to modify too much _________________ 1980 924 header port+polish weltmiester sp250 front springs 944 quarters and fenders
85.5 944 stock |
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Tue Jun 09, 2009 2:52 pm Post subject: |
I believe that fronts are exactly the same and rears only slightly different but please dont rely solely on this. With the rears I used 951 rear shocks on my 924 and only required very slight mods (the other way may be harder however as I think that I had to make a spacer to fill my mounting hole out of a steel tube so to put 924 rears on a 944 you may have to make a larger hole which would not be a great idea) But again I think fronts are identical. _________________ 1977 924 2.0 Auto |
gohim
Posted: Tue Jun 09, 2009 5:00 pm Post subject: |
| Front struts are interchangable. I have the low pressure non-adjustable Koni front gas struts (standard front struts on 85.5 944) installed on my 81 924. I put them on when I switch to four wheel disc brakes over 10 years ago. |
toolboxterrorist
Posted: Wed Jun 10, 2009 7:13 am Post subject: |
cool sounds like the front struts will go right in now my question is what are better stock 85.5 944 struts or dampening adjustable koni's i am assuming the koni's just want to be shure _________________ 1980 924 header port+polish weltmiester sp250 front springs 944 quarters and fenders
85.5 944 stock |
