Dutch924-racer
Posted: Fri May 15, 2009 5:28 am Post subject: Tig welding questions + pictures |
I bought a tig welder, does anyone know how to adjust it and what are the settings to weld aloy between 2mm and 4 mm thickness.
The buttons I want to know are:
starting
current
slop down
pre flow
post flow
local - remote
min-max
See pictures in the link below.
I know i should put it on AC for aloy welding.
 _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Last edited by Dutch924-racer on Sat May 16, 2009 1:54 am; edited 2 times in total |
Abet
Joined: 31 Aug 2005 Posts: 17 Location: Brisbane Australia
Posted: Fri May 15, 2009 8:29 pm Post subject: tig |
Have not seen this brand machine before but they are all fairly similar.
Min-Max is for the current range, there are two scales on the current dial.
Local-Remote is to use a button on the torch (remote)
Pre-flow sends gas for a short time before welding (probably only remote)
Post-flew sends gas for a short time after welding (probably only remote)
Starting might be a hotter current when you start welding
To weld aluminium you need a high frequency machine I noticed a fuse there with H-F so hopefully just set the machine on about halfway on max and practice on some 3mm.
Have Fun _________________ 1981 924 Turbo |
Dutch924-racer
Posted: Sat May 16, 2009 1:56 am Post subject: |
Thanks for your replay,
What should I set the swichtes to, I have no idea.
starting
current
slop down
pre flow
post flow
min-max _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Martijnus
Posted: Sat May 16, 2009 2:01 am Post subject: |
looks like a nice machine.
I always find it magical to see all those buttons and don't know what they are intended for...but there have to be people who understand it.
Luckily now I know a bit about it too thanks to Abet
I think there are settings to get you in the ball park, but my guess is it just takes a lot of experience to interact with such a machine... you have to have seen enough situations to know what setting #### up what material etc.
Can't help you any further, but just try some stuff. My welding machine has only 2 settings...min and max. And even that's too complicated for me at some times. Max isn't always the best option so I always tried min to be sure I won't melt all my metal away... but I've found out max is much more fun.
welding.... it's an art I can't master.
edit: hey...censorship on the board. wtf  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Abet
Posted: Mon May 18, 2009 7:47 pm Post subject: |
If you have not tried the machine yet I suggest that the settings in the photo would be a fair place to start. Looks like the current is set to about about 90 amps. Put everything else in the middle and see what happens on a piece of 3mm.
Cheers _________________ 1981 924 Turbo |
