wheel spacers
badlad69er
PostPosted: Mon May 18, 2009 9:03 am    Post subject: wheel spacers Reply with quote
which size wheel spacers are needed for the carrera gt replica kit ?? 17mm, 20mm, 25mm, 40mm???
1982 - 924 Lux
Next Mods - Carrera GT Kit, 944 Turbo Wheels, 5 Lug Conversion.
Engine Mod to be Done - Install a Nissan 200SX Engine (last job not for anthoer year or two)
PostPosted: Mon May 18, 2009 9:46 am    Post subject: Reply with quote
It all depends on which wheels you plan to run and what offset they are.
Scorpio
PostPosted: Mon May 18, 2009 10:03 am    Post subject: Reply with quote
exactly right!..oohh and tyre width..the buldge makes a difference
i have a 9 inch rim 245 40 17 tyre with a 20 inch offset and a 1 inch spacer (about 25 mm) on the rear and it looks PHAT
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
peterld
PostPosted: Mon May 18, 2009 10:32 am    Post subject: Reply with quote
20 INCH OFFSET! I'd like to see that! See Scorp - Birthday Party has addled your brain -must be all those chicks!!!
ic932
PostPosted: Mon May 18, 2009 5:22 pm    Post subject: Reply with quote
If you are going for a more modern Porsche rim for example Design 90's then 30+mm spacers are needed in order for the wheel not to look lost in the wheel arches. If you want period rims like Fuchs or Cookie cutters then no spacers are required.
The basic rule of thumb is any rim with an offset of 23mm or lower will not need a spacer. Any rim 53mm or higher will need a spacer.
Did you have you eye on a particular style of wheel?
Scorpio
PostPosted: Mon May 18, 2009 7:58 pm    Post subject: Reply with quote
mmmm not entirely true...anything wider than a 7 inch rim even with a low offset will need a spacer
sorry Petey got confused 20 inch wasnt my offset
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PostPosted: Mon May 18, 2009 8:24 pm    Post subject: Reply with quote
It depends on what suspension you have and what wheels you want to use.
First thing you should do is to identify the 5 lug suspension you are going to use...the older it is the bigger spacers you'll need.
After that you need to clear what rims and tires you want to use.
dont neglect the front end...you can end up using spacers on the rears and hudge spacers on the fronts.
I'm using the 931 front suspension and 944S2 rear suspension together with 911 17" wheels...this setup requires a 25mm spacer on the rears and a massive 35mm spacer on the front wheels...so be carefull what you shop for.
badlad69er
PostPosted: Mon May 18, 2009 8:36 pm    Post subject: Reply with quote
hey guys thanks for all the suggestions but i was thinking of buying the bilstein coilovers and dampers kit from porscheshop.co.uk but do you think i should buy 931 front and 944s2 rear suspension?? the wheels i was thinking of buying are an aftermarket new kei rss wheels 17" similar to the rsgt wheels and hoping that would give the car a modern and different look.
Thanks, Luke
1982 - 924 Lux
PostPosted: Mon May 18, 2009 8:57 pm    Post subject: Reply with quote
i'm not talking about dampers and coils...but about suspension arms and hubs...they differ in length so this alters the wheel offset.
