Slightly OT BMW
datatrain
PostPosted: Wed Jul 08, 2009 4:25 am    Post subject: Slightly OT BMW Reply with quote
I know many of you have a BMW. My 92 BMW 318i alternator failed and when I pulled it out I saw in the bay the cable for the Mass air sensor and the throttle position sensor but also a third 2 pin connector as part of the bundle. This connector doesn't seem to have a home. The cable length indicates it should be close. I wonder if anyone can identify this orphan ?
I've found the BMW forum to be less than helpful in the past.
Thnx
DAve
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
xpernet
PostPosted: Wed Jul 08, 2009 12:37 pm    Post subject: Reply with quote
Try www.m42club.com
I used to own a 1992 318i... awesome cars, loved mine to death!
Bimmer forums are less than helpful when it comes to the 4 cylinder BMWs because they dont think its BMW enough... its alot like the 924 in the Porsche world!
(p.s i got an ecu chip and some other parts too if u need anything)
1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
wombat
PostPosted: Wed Jul 08, 2009 5:52 pm    Post subject: Reply with quote
On an early E36 I think that the wire you described goes to the Idle speed control valve but this is only for the M40 engine, it is the only 2 pin wire I can think of in the vacinity of the throtle position sensor, but it has been a while since I had an E36 and never a 4 cylinder, I had a look at my E46 and couldnt find the wire you described.
1977 924 2.0 Auto
datatrain
PostPosted: Fri Jul 10, 2009 4:30 am    Post subject: Reply with quote
As it turned out the connector was for the Fuel vapour purge valve. After 4 years the check engine light is finally off.
Mint '92 318i BMW
VE7HFR
