Clutch kit for 924 turbo
jhazels
PostPosted: Tue May 05, 2009 6:41 pm    Post subject: Clutch kit for 924 turbo Reply with quote
Hello everybody - I have a significant clunk around the gearbox in the rear of the car. There is also a certain slackness in the rear wheels when the car is jacked up and in gear. I have diagnosed it as a bad clutch where I think the centre goes.
Is there a suitable clutch kit? If so which one is best and where can I source one and for how much - I am in Australia. I also need a clutch master cylinder.
Thanks - John H
The Australian Motorist
elitejaso
PostPosted: Wed May 06, 2009 12:47 am    Post subject: Reply with quote
What you want is a SACHS clutch kit.
Porsche will probably charge you at least $2000 for one so i recommend lookin in the states. Alot cheaper even with the exchange rate.
Try searching www.stoddard.com have bought most of my items from them in the past and they're not as expensive.
Otherwise heres one kit for sale on ebay, will cost just under $1000 AUSD to have it shipped to your door.
http://cgi.ebay.com/ebaymotors/SACHS-1980-82-PORSCHE-924-2-0L-TURBO-CLUTCH-KIT-KF20002_W0QQcmdZViewItemQQ_trksidZp3286Q2em63Q2el1177QQhashZitem320366988989QQitemZ320366988989QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Good luck
1981 924 turbo (daily driver)
PostPosted: Wed May 06, 2009 12:51 am    Post subject: Reply with quote
Don't forget your clutch slave. . .if you master is bad, the slave is likely close behind.
jhazels
PostPosted: Wed May 06, 2009 11:03 am    Post subject: Thanks for your help Reply with quote
Thanks - really appreciated. elitejaso - it seems you have a lot of knowledge - any ideas who can fit it at a reasonable price?
