G31 box' separating gear from dog teeth
Elektrobank
PostPosted: Mon Mar 02, 2009 5:02 am    Post subject: G31 box' separating gear from dog teeth Reply with quote
Hi all!
i have two G31 that have the usual 2nd gear that grinds sometimes...
my thoughts of the night are the following:
both 3rd gear on both gearbox are in very good shape... so..
separate one dogteeth form a third gear and press it on a second gear with relative syncro and survive for the next 20.000 kilometers... more or less 4 years... during this time many things can happens like win money somewere and buy new gearset
on the first gear looks to be simple this kind of operation a good puller can be made if used with the big and thick seeger that holds synghro and brake bands in place
but 2nd and 3rd gear do not have this option so.. how this can be done?
any help will be much appreciate
Thanks in advance
Gianluca
924T Dta inj + sequential LPG
Cosworth
MotoMorini 501
Moto Morini 350 K2
lot of fun but always on foot....
john h
PostPosted: Mon Mar 02, 2009 8:52 am    Post subject: Reply with quote
Before you start pulling everything to bits check and make sure the 2nd gear dog tooth is the same as the third gear.
From memory 1'st and 2nd are unique to the G31 box, third is from a type 915 gear box (911) and 4th and 5th are able to be swapped around.
I haven't pulled a gearbox apart for many years now so my memory could be faulty.
Elektrobank
PostPosted: Mon Mar 02, 2009 8:59 am    Post subject: Reply with quote
second gear and third gear have the same dogteeth, they share the sleeve that engage the gear so they have the same outer diameter and the same number of teeth
first gear dogteeth is a problem... w-out solution at the moment..
Cosworth
MotoMorini 501
Moto Morini 350 K2
v8carreragts
PostPosted: Fri May 08, 2009 12:55 pm    Post subject: Reply with quote
Crrect. 1st is unique, 2nd and 3rd are the same (may be able to use an early 928 part) and 4th and 5th are the same as the 915. I havent tried it yet but I believe that if you change the sybchro hub for 2nd and 3rd you can use 915 parts including gear sets. I have all of the parts on the bench but haven't had time to try and assemble it this way.
