Posted: Sat Jun 07, 2014 12:11 pm Post subject: how do i fix this hatch trim seperating from the glass? |
I tried and tried and tried pushing this trim back on where it looks like its supposed to be on the other side to no avail...
6 hands on it and still no dice...
how can this be fixed?
if I cant figure it out myself a glass shop is gonna get it once I get this thing on the road
oh, it doesn't leak btw _________________ 80 Turbo - Slightly Modified |
jason c
Posted: Sat Jun 07, 2014 1:05 pm Post subject: |
You'll have to take it off & apart, then reglue it with a good glass primer & glue.
You'll be lucky if it works long term. Unlikely you'll find a glass shop that will touch it.
The easiest route is to find another hatch in good condition. They're 2K new & a dime a dozen used. |
Posted: Sat Jun 07, 2014 1:27 pm Post subject: |
im pretty sure the glass is in the right place but the trim wont go on...
if what you said is the case then I aint gonna fuss with it _________________ 80 Turbo - Slightly Modified |
jason c
Posted: Sat Jun 07, 2014 1:37 pm Post subject: |
| The "trim" is the frame. The pressure from the lift struts push the frame off the glass. It will only get worse. Always lift the hatch from the center in the rear to avoid twisting of the hatch, it will help keep the glass & frame from separating. |
Posted: Sat Jun 07, 2014 2:19 pm Post subject: |
ooh wow now that I look at the pet I can see whats going on here...
I was going on about this the wrong way...
I was trying to push the trim back down onto the window..
it looks like I need to push the window back up onto the frame...
or just don't touch it? _________________ 80 Turbo - Slightly Modified |
Posted: Sat Jun 07, 2014 3:29 pm Post subject: |
Did you search? Easy fix HERE. _________________ Toofah King Bad
Posted: Sat Jun 07, 2014 3:33 pm Post subject: |
| Rasta Monsta wrote: | | Did you search? Easy fix HERE. |
yeah I searched...
learned not to use a flat head screw driver trying to separate it.. _________________ 80 Turbo - Slightly Modified |
Posted: Sat Jun 07, 2014 3:38 pm Post subject: |
yep..
the one I thought of when YOU mentioned it
read that one a while ago _________________ 80 Turbo - Slightly Modified |
jason c
Posted: Sat Jun 07, 2014 3:54 pm Post subject: |
| Fasteddie313 wrote: | ooh wow now that I look at the pet I can see whats going on here...
it looks like I need to push the window back up onto the frame... |
Its a little of both. You can tell the frame is pushed towards the roof by the narrower gap.
| Fasteddie313 wrote: | | or just don't touch it? |
That's the safe bet. Better make sure you can keep water out of the car while you're looking for a new hatch after you break this one. It takes a lot of patience to repair these. It might take a couple tries to get it to last. |
Kens_74_911s
Joined: 01 Mar 2011 Posts: 529 Location: Southern Pines , North Carolina USA
Posted: Sun Jun 08, 2014 1:41 pm Post subject: past fails documented |
If you can remove the frame or pull it back far enough and sand blast the glass in that area you have a better chance of it being a permanent bond.
I have 4 hatches if someone needs some to fix. Can strap to a pallet and ship
K _________________ Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars |
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Fri Jun 13, 2014 4:16 pm Post subject: |
I've gone through the trouble of repairing separated glass. Bought 3m window bond or whatever it's called, did lots of prep and clamping and let dry for a few days. The hatch remained fixed for maybe three days and/or five openings.
Seriously, the only solution that's out there is to find a used one that has remained in good shape after all these years. Otherwise it's my current solution: a couple nice strips of black electrical tape across the gap. Holds on for years and keeps the water out! _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Posted: Fri Jun 13, 2014 6:52 pm Post subject: |
I have a line on an 83 944 non roller locally that has a whole good hatch...
might wind up with the whole shell... no engine, torque tube, tranny, maybe no suspension... no front bumper or fenders
good doors and hatch AND ENTIRE BLACK INTERIOR WITH GOOD SEATS
might have some parts for you guys too soon
going to look this Saturday, I AM coming home with that hatch at the very least _________________ 80 Turbo - Slightly Modified |
MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Fri Jun 13, 2014 11:00 pm Post subject: |
If that purchase doesn't go through, drop me a line. I have an original hatch from my '76 sitting in the garage. I upgraded to a 944 hatch and it works. I can send you pics if you like. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Posted: Sat Jun 14, 2014 5:03 am Post subject: |
cool.. Vancouver is a ways tho.. _________________ 80 Turbo - Slightly Modified |
Posted: Sat Jun 14, 2014 5:25 am Post subject: |
erm I mean Ontario....
its still Canada... _________________ 80 Turbo - Slightly Modified |
