windscreen washers and hot start
scotthusky89
PostPosted: Mon Mar 23, 2009 8:07 am    Post subject: windscreen washers and hot start Reply with quote
just querying if any one can help in regards to my washer on my car are not working, ive tried the pump with direct power and the pump works but i noticed that when i put a multi meter test on the orignal connectors im only getting 1.3 volts to the pump instead of the 12v , when i pull stalk towards me the wipers dnt mve neither does the pump work but if i remove the terminals from the washer pump then the wipers come on but as son as i connect the pump back up neither work and i only get the 1.3 volts to it could it be a relay or something,
and as regards to the hot start problem i think ive asked about this but what is the major cause of the hot start prblem
thanks scott
hi everyone nice to see and talk and hear from u
82 924turbo s2 english rhd verson
View user's profile Send private message AIM Address MSN Messenger
PostPosted: Mon Mar 23, 2009 8:20 am    Post subject: Hottie! Reply with quote
My hot-start problems were soley related to a bad fuel accumulator. Plus, after fixing it, the AFR was off, a lot!
scotthusky89
PostPosted: Mon Mar 23, 2009 8:51 am    Post subject: Reply with quote
what does afr stand for
PostPosted: Mon Mar 23, 2009 9:17 am    Post subject: Reply with quote
Air/Fuel ratio. Adjustable, using the little 3mm hex screw on CIS distributor. Will screw and hex with your life!
PostPosted: Mon Mar 23, 2009 9:37 am    Post subject: Reply with quote
The hot start problem is the ages old vapor lock issue where the fuel boils in the fuel lines after the motor is shutdown.
To avoid this, Porsche runs the radiator fan after shutdown and the fuel injection system when working properly maintains pressure after shutdown. This pressure raises the boiling point of the fuel so it does not vaporize.
White 87 924S "Ghost"
scotthusky89
PostPosted: Tue Mar 24, 2009 5:41 am    Post subject: Reply with quote
so which way to turn hex screw then t in rich it or decrease the mixture and which is best
PostPosted: Tue Mar 24, 2009 8:52 am    Post subject: Reply with quote
Please leave it alone until you have tested the system and control pressures.
PostPosted: Tue Mar 24, 2009 9:11 am    Post subject: Reply with quote
Oh, don't chase after that! Do what Paul says first, I wasted more time than I care to admit playing that card!
