orange julius
Joined: 20 Oct 2009 Posts: 16 Location: Barrie,Ontario,Canada
Posted: Tue Oct 20, 2009 10:18 pm Post subject: Knocking |
Hi ,
Just new to this board and also new to Porshe- just bought my first 1980 924.
I have a bit of an engine knock- what causes this- the car runs fine, doesn't appear to burn any oil _________________ Orange Julius |
Rich H
Posted: Tue Oct 20, 2009 10:42 pm Post subject: |
What oil pressure do you have at hot idle?
Is it defiantely a knocking or more of a tapping? These cars have mechanical tappets that need adjusting occasionally. they are generally quite noisy. _________________ 1994 Lotus Esprit S4 - Work in progress...
orange julius
Posted: Tue Oct 20, 2009 10:52 pm Post subject: Engine Knocking |
I will check out the oil pressure later today- you could describe it as a tapping sound. Is it difficult to adjust the tappets yourself?
I expect I would have to have new valve cover gaskets around before I would start this. _________________ Orange Julius |
Rich H
Posted: Tue Oct 20, 2009 11:09 pm Post subject: |
Valve cver gaskets are normally fine, I've reused mine several times with no leaks.
Tappets isn't hard to do if you can work a spanner adn follow instructions. You will need a 3mm allen key (L shaped) and a set of feeler gauges in addition to normal spanenrs and sockets. Takes about an hour or so first time.
Search is your friend.
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Oct 21, 2009 4:03 pm Post subject: |
FYI, you have posted in the 924S section, which is intended for discussions on the 924 that came with the same type of engine that the 944 used. These were not available in the year you mention your car was made.
This is more appropriate in the General Discussions section. _________________ 78 924 NA
5-lug |
orange julius
Posted: Wed Oct 21, 2009 10:09 pm Post subject: Tapping |
Will try the general discussion as well.
Thanks. _________________ Orange Julius |
