Side mirror wires
ole billy
PostPosted: Fri Mar 13, 2009 10:26 am    Post subject: Side mirror wires Reply with quote
Want to remove the side mirrors to have mirror frame and door painted. The wires for mirror, window switch and motor come into the door. The mirror wire has a female plug with six wires. Is there a tool or trick to get the wires out of this plug. Want to pull wire back through mirror frame so it can be removed, taked apart and painted. This is on a 87' 924s where all of the wires are bundled when they come through the body frame to the door.
PostPosted: Fri Mar 13, 2009 11:26 am    Post subject: Reply with quote
Pin tool #305183 works on those pins. $15.95 here - http://www.action-electronics.com/molex.htm#Tool
relevant topics -
http://www.924board.org/viewtopic.php?t=11146
http://www.924board.org/viewtopic.php?t=5758
joecitizennn
PostPosted: Fri Mar 13, 2009 11:41 am    Post subject: Reply with quote
Or the really skilled German car mechanic uses a method called kutzen-splicen.
PostPosted: Fri Mar 13, 2009 8:39 pm    Post subject: Reply with quote
Katzen spleissen! Stripping Cats ?
PostPosted: Fri Mar 13, 2009 9:48 pm    Post subject: Reply with quote
No no no no! Don't cut!!!
