Porsche 924 / 968
Rob_Hooper
PostPosted: Thu Jan 29, 2009 6:30 pm    Post subject: Porsche 924 / 968 Reply with quote
Hi Guys,
I am rebuilding my 924 currently to race in a new class here in New Zealand, german renn sport,
I am putting all of my crashed 968 parts into my 924 race car.
I have fitted all of the suspension and am using the Aluminium cross member form the 968 (required some welding and changing mounts)
Car will be running full perspec and is currently just a shell, this is a full race car. Aiming for less than 900kg.
I am running a 944 turbo S gearbox with the standard 17inch Cup wheels from the 968. I am really stuck on the suspension to buy, especially since the New Zealand dollar is so weak at the moment.
Any ideas on what can be done here?
I know there is some other posts here on the topic but i really was after those who had converted to 944 turbo or simular setup.
Quetions around:
Spring rate,
Shocks,
Any help will be appriciated,
I will post pics of where i am up 2 soon,
Cheers Rob
924
931
968 CS
J1NX3D
PostPosted: Thu Jan 29, 2009 7:27 pm    Post subject: Reply with quote
nice project! Would love to see more
'86 944
Andrew NZ
PostPosted: Thu Jan 29, 2009 7:50 pm    Post subject: Reply with quote
Sounds like it'll be quite a car!
Tell me more about this new class, I haven't heard anything about it yet - is it just a South Island class?
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
PostPosted: Thu Jan 29, 2009 10:40 pm    Post subject: Reply with quote
You should be able to source everything you need from stock OEM parts, and there are a variety of options available for you to consider, which can be put together in any number of permutations. I've tried to document most of what I've researched here, including a systematic methodology for evaluating the critical design choices and associated dependencies:
http://www.924board.org/viewtopic.php?p=218957#218957
Bear in mind, that thread is based on theoretical research...while I've used this approach to arrive at my own design choices, I am still in the middle of acquiring everything and getting the suspension built. It would be great to get some independent, real world feedback on how accurate and useful the approach is, so if you take time to read and follow the suggestions, I'd love to get your feedback.
Also worth reading:
Rob_Hooper
PostPosted: Sat Jan 31, 2009 8:34 am    Post subject: Reply with quote
German Renn Sport is a new class here in New Zealand, and the rules are completly open. You must have a german car with a german engine. All cars welcome except porsche cup cars. Fastest car in the class in a 2.8L M3 (E30 M3) and then a 318i super touring car.
I am hoping to give them a run, cant have BMW's beating porsches in races can we!!!!
I will post some pics in the next few days.
Cheers Rob
924
931
968 CS
PostPosted: Sat Jan 31, 2009 11:00 am    Post subject: Reply with quote
I think you should call it the 2-4-6-8
Ooooo, I'm funny
PORSCHEV
PostPosted: Sat Jan 31, 2009 11:28 am    Post subject: Reply with quote
Just to clarify ..you are going to run the 968 power plant?
1978-#53 "D" track racer.
Rob_Hooper
PostPosted: Mon Feb 02, 2009 4:48 am    Post subject: Reply with quote
Yes, it will be a 968 powered beast,
I brought the 968 as a crashed car (it has been hit in the back) i then later discovered that it was a CS!, I was going to convert to RHD and then put it back on the road here but i was going to cost too much.
My 924 has been in the garage for a long time and its mere 135hp in race trim is just too slow now days for most racing
So i figured, bugger it, i will stick the 968 stuff into the 924..
I thought about rebuilding the 968 into a race car, but the costs would have been higher as the 924 already has a cage etc plus i prefer the 924 shape.
I am not sure if anyone else has done this conversion for a race car?
but i am hoping that the 240+ hp of the 968 engine will really get this thing going.
Cheers Rob
924
931
968 CS
Rob_Hooper
PostPosted: Mon Feb 02, 2009 4:54 am    Post subject: Reply with quote
Has anyone used this coilover pakage?
Comments?
http://www.paragon-products.com/ProductDetails.asp?ProductCode=BILSTEIN%5FESCORT%5FCUP%5F944%2DXDO
Cheers Rob
924
931
968 CS
PostPosted: Mon Feb 02, 2009 6:05 am    Post subject: Reply with quote
it will probably work fine, theres a race 924s (wich do makes a swap easier) here in sweden that got some 944s2/968 stuff. Some new mounts has to be done and so on. Seems like a nice proejct !
FRporscheman
PostPosted: Fri Feb 27, 2009 6:36 pm    Post subject: Reply with quote
I love the fender flares on that 924! So... un-944.
'93 968
'84 944
82 MB 300td
jazz guy
PostPosted: Sat Feb 28, 2009 1:09 am    Post subject: Reply with quote
+1 Great look!
Martijnus
PostPosted: Sat Feb 28, 2009 3:38 am    Post subject: Reply with quote
I agree
"Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Killed her at the Nurburgring, Porscheless at the moment
