steering bush in the bulk head help
benlg81
PostPosted: Mon Feb 02, 2009 8:20 pm    Post subject: steering bush in the bulk head help Reply with quote
Hi All
the saga of the car is almost over, taxed fully serviced running lovley then.....
clunk the steering wheels goes up and down, found the problem to be the bush at the bottom of the steering coloum that fits in the bulk head pushed this in as far as i could on saturday and it was all good until i turned up at work today and then just as i pulled onto the car park it popped back out.
is there a technique to get this all the way in? also is it fixed in or does it just fit?
cheers
Ben
benlg81
PostPosted: Tue Feb 03, 2009 5:29 am    Post subject: Reply with quote
found out it will only go in if you take the wheel and the ignition barrell off. so it is back in place and walloped in tight so fingers crossed it stays in.
any ideas to keep it in?
