windscreen trims
944cabby
PostPosted: Fri Jan 23, 2009 4:47 am    Post subject: windscreen trims Reply with quote
Does anyone know if it's possible to replace the metal trims that go around the windscreen on a 924 with the rubber seals that are fitted around the screen of 944's?
1977 martini 924
1983 met claret 924 lux (sold)
1979 burgundy 924 (broke it for spares)
PostPosted: Fri Jan 23, 2009 6:02 am    Post subject: Reply with quote
Yes, if you're referring to the early 944...
2Fast
PostPosted: Fri Jan 23, 2009 1:10 pm    Post subject: Reply with quote
I believe so...heres a link for you. Hope it helps some. http://www.924board.org/viewtopic.php?t=22873
=====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd
944cabby
PostPosted: Fri Jan 23, 2009 8:07 pm    Post subject: Reply with quote
Thanks for the replies guys.
1977 martini 924
StienbargerR
PostPosted: Sat Jan 24, 2009 11:15 am    Post subject: Reply with quote
Cant think of his name at the moment, but The Canadian guy with the Yellow V8 conversion has done that.
Ryan
1978 924 NA
PostPosted: Sat Jan 24, 2009 11:50 am    Post subject: Reply with quote
PORSCHEV
PORSCHEV
PostPosted: Sat Jan 24, 2009 12:17 pm    Post subject: Reply with quote
Yeah it was that "Canadian guy" Lmao
1978-#53 "D" track racer.
PORSCHEV
PostPosted: Sat Jan 24, 2009 12:22 pm    Post subject: Reply with quote
Here are some close up pics. This is a standard 924 glass with a generic aftermarket rubber trim that most glass stores will have in stock by the roll.
944cabby
PostPosted: Sat Jan 24, 2009 11:29 pm    Post subject: Reply with quote
Cheers Porschev - on my martini pretty much most of the rust has started from around the windscreen trims so when i've got it sorted i plan to fit these rubber trims.
1977 martini 924
PORSCHEV
PostPosted: Sun Jan 25, 2009 12:24 am    Post subject: Reply with quote
I should inform all that this trim that I have install actually hooks onto the edge of the glass before it is installed the same way most of the modern window trims are done now.
