american bumpers closer to body
Goto page 1, 2, 3  Next
thirdgenbird
PostPosted: Sat Nov 08, 2008 12:16 pm    Post subject: american bumpers closer to body Reply with quote
I've noticed that there are several cars on here what have american front bumpers that are closer to the body.
how do i do this?
can i do it on the rear as well?
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
alexvex
PostPosted: Sat Nov 08, 2008 12:55 pm    Post subject: Reply with quote
It's easy to do on the fronts...get under the car and look at the bumper. There are two shocks that hold it on. Take a drill and drill a hole into them until liquid shoots out (this can be done with bumper on or off). Then just push the bumper in and it'll hold there.
The rear is a lot more complicated. You have to cut/weld the mounts and then fab up some sort of filler panel to make the bumper line up with the body right and take up the space from the black rubber sides.
It's amazing how much better they look with it pushed in:
--Alex--
2010 Touareg TDI
Past Pcars: 80 931, 87 924S, 87 951
thirdgenbird
PostPosted: Sat Nov 08, 2008 12:58 pm    Post subject: Reply with quote
thanks! is there a good place to get a euro rear bumper? that seems a lot easier
PostPosted: Sat Nov 08, 2008 1:01 pm    Post subject: Reply with quote
Alex your car looks hot though a little. Ride height is a little off
you 4 wheel that thing.
alexvex
PostPosted: Sat Nov 08, 2008 1:08 pm    Post subject: Reply with quote
Damn 65 profile tires.
--Alex--
2010 Touareg TDI
thirdgenbird
PostPosted: Sat Nov 08, 2008 1:40 pm    Post subject: Reply with quote
anyone have any pictures or a how to?
alexvex
PostPosted: Sat Nov 08, 2008 1:49 pm    Post subject: Reply with quote
I believe Vince has done this and has posted a technique..hopefully he'll chime in here.
--Alex--
2010 Touareg TDI
thirdgenbird
PostPosted: Sat Nov 08, 2008 1:53 pm    Post subject: Reply with quote
i did a search but it didnt seem to return anything
StienbargerR
PostPosted: Sun Nov 09, 2008 7:18 am    Post subject: Reply with quote
Yeah. I pushed mine in all the way. Wear some safety glasses! The fluid inside IS under pressure, so be safe! I had mine welded in place, I think thats the best way to do it.
Ryan
1978 924 NA
Vince Ponz
PostPosted: Mon Nov 10, 2008 12:11 am    Post subject: Reply with quote
Both front and back can be done without a problem. Remove bumper, remove shock. Cut shock about 1 in from the rear with a hack say. Push in till liquid drains and wash out residue. When dry weld shut after you compress the piston. Make sure the mount is perfect to mount the bumper. If it is crocked you cannot put the bumper on.
Works the same on the front and rear. On the rear you will toss out the black FILLER. That what that is and it is ugly. [my opinion] Somewhere recently Peter Au posted pictures of my car and you can see what the pushed in bumpers look like. As for you outside NA you know what I mean.
Problems? PM me.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
thirdgenbird
PostPosted: Mon Nov 10, 2008 12:34 am    Post subject: Reply with quote
sounds great. i may just fabricate new bumper mounts instead, but i do plan on pulling my bumpers in, it look great. thanks everyone.
StienbargerR
PostPosted: Mon Nov 10, 2008 3:06 pm    Post subject: Reply with quote
Im not trying to shoot your idea down, but modifying the existing bumpers is much more cost effective. Used bumper shocks are super cheap, so if you mess one up, you are only out like $12
Ryan
1978 924 NA
PostPosted: Mon Nov 10, 2008 3:45 pm    Post subject: Reply with quote
what you do takes maybe all of 45 minutes, Is to remove
the bumper mounts drill them out with a drill and then push them
in all the way and run a couple of machine screws thru them to keep them in... thing is watch out cause once you puncture the inner
sleeve its like pressurized and an oily like discharge shoots out of the hole your drilling...
PostPosted: Wed Nov 12, 2008 4:16 pm    Post subject: Reply with quote
What no comments... sure you can fab some up from scratch... guess thebest would be to drillem, drainem then weldem... after pushin im in all the way.
thirdgenbird
PostPosted: Thu Nov 13, 2008 5:31 am    Post subject: Reply with quote
thanks all for the input. i would have replied sooner but i got a new cell phone and one of the settings was wrong and i couldn't get the forum to work on it.
i have not done it yet, but i hope to get them drilled out and pushe in this weekend
Page 1 of 3
