Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Fri Oct 10, 2008 3:31 am Post subject: oil temperature gauge sender, where to put ? |
I have a oil temperature sender in te top hole of the carter in my normal 924.
I also want one in my 931 S2, but the hole is used by the oil return line.
Any solutions ? I saw the GT in the original Porsche 924/944/968 book has an oil tmep. gauge, so it is possible to put it else where. _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Posted: Fri Oct 10, 2008 4:03 am Post subject: |
1. Drill and tap another hole in the oil pan
2. Run an oil filter straight-through sandwich adapter
Option 2 doesn't modify your motor, but will require you to run a shorter filter. This is what I'm doing on my 941. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Oct 10, 2008 5:24 am Post subject: |
I put mine in the oil filler plug. Just drill and tap, works great. _________________ 1980 924 Turbo
Posted: Fri Oct 10, 2008 5:28 am Post subject: |
| Cédric wrote: | | I put mine in the oil filler plug. Just drill and tap, works great. |
oil filler plugs are supposed to be replaced periodically. it works ok, but becomes a higher maintenance approach than the two listed above... _________________ erstwhile owner of just about every 924 variant ever made |
bruni
Joined: 26 Jul 2008 Posts: 114 Location: South Africa
Posted: Sat Oct 11, 2008 5:11 am Post subject: |
oil filler plugs are supposed to be replaced periodically[quote]
Why? _________________ 1982 931
1975 harley sportster |
Posted: Sat Oct 11, 2008 5:59 am Post subject: |
Because the good doctor recommends it in the service manual? _________________ erstwhile owner of just about every 924 variant ever made |
bruni
Posted: Sat Oct 11, 2008 6:21 am Post subject: |
I ask again why? does it wear out? it makes no sense, how often do they recommend that it is changed _________________ 1982 931
Posted: Sat Oct 11, 2008 7:17 am Post subject: |
I don't know the why part. I presume because like most fasteners the threads over time lose their ability to retain proper tension. I do know that on ALL of my cars, the drain plugs that were in them when I got them were leaking even with new crush washers, so I replaced them all with new plugs, problem solved. _________________ erstwhile owner of just about every 924 variant ever made |
bruni
Posted: Sat Oct 25, 2008 9:43 am Post subject: |
VDO make an oil drain plug with a built in sender for Porsche.
Having now looked at the porsche drain plug i believe the problem is with the head of the drain plug not the thread, the head on the VDO sender is much more substantial and should last the life of the sender unit, I trust this is of assistance _________________ 1982 931
Posted: Sat Oct 25, 2008 10:27 am Post subject: |
How about a part number  _________________ erstwhile owner of just about every 924 variant ever made |
bruni
Posted: Sat Oct 25, 2008 11:32 am Post subject: |
VDO 300F Temperature Sender m14 x 1.5
Part Number: 323 055D _________________ 1982 931
