home made short shifter
Benino
PostPosted: Sat Dec 22, 2007 6:25 am    Post subject: home made short shifter Reply with quote
I'm planning on shortening the shift lever that clamps onto the selector shaft that comes out of the transmission to make my own short shifter. Does someone know the measurement on the short shifter from the center of the selector shaft to the center of the rod that connects to the rest of the linkage? I don't want to make mine too short, but if I don't make it short enough it won't be worth the work.
Heres a picture of the part and measurement I'm talking about. Can someone measure this distance on the short shifter kit? thanks.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
joecitizennn
PostPosted: Sat Dec 22, 2007 11:27 am    Post subject: Reply with quote
Dont forget, you can also move the connecting shift rod (#8) higher on the gearshift for a shorter throw.
And you might want to shorten the side to side throw by lengthening this.
haroldk
PostPosted: Fri Dec 05, 2008 8:06 am    Post subject: Reply with quote
Mine measures out at about 15cm. It might be more like 15.2cm, but 15cm is pretty close.
PostPosted: Fri Dec 05, 2008 9:13 am    Post subject: Reply with quote
Hope it works I made a short shift handle a nice one Ill have to post a pic sometime.
haroldk
PostPosted: Fri Dec 05, 2008 9:52 am    Post subject: Reply with quote
Man, I read that date wrong. Somehow, I thought the last post before mine was from 11/22/08.
PostPosted: Fri Dec 05, 2008 10:14 am    Post subject: Reply with quote
Aye, indeed it's an oldie but a goodie.
PostPosted: Fri Dec 05, 2008 6:56 pm    Post subject: Reply with quote
yea well maybe benino will tell us what happend or what came of it how about it benino
924-76
PostPosted: Fri Dec 05, 2008 8:41 pm    Post subject: Reply with quote
It is about 2”3/16 or 5.6 cm.
I attempt the same last summer, I cut ˝” and it was a bit to much because the selector shaft connector couldn’t clear the top of the tranny be about 1/8".
Let us know the result and how much did you cut.
haroldk
PostPosted: Fri Dec 05, 2008 10:22 pm    Post subject: Reply with quote
Cripes, I guess that shows how out of it I was when I measured. I offset the tape to 10cm to make it easier to center and forgot that when I posted. Although I suppose somebody making one 15cm long would probably notice that right off the bat...
PostPosted: Sat Dec 06, 2008 5:08 am    Post subject: Reply with quote
The short handle i made is kind iof like a pistol grip though theres no finger grooves its more like a oblong short shaft .
