Optima battery
dash16
PostPosted: Thu Jul 23, 2009 8:16 am    Post subject: Optima battery Reply with quote
Was thinking about getting one of these:
http://www.optimabatteries.com/optima_products/redtop/specs.php
but can't seem to figure out which one I need.
I also hear that German cars need a "group 48" and there are no 48s offerred in the BCI group (not sure if that the same thing)
OR
suggest a battery
thanks
1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS
PostPosted: Thu Jul 23, 2009 2:04 pm    Post subject: Reply with quote
PostPosted: Thu Jul 23, 2009 4:22 pm    Post subject: Reply with quote
While Optima batteries are truly the best you can buy (I have one in my 914 that's been in service for over 20 years), they are really necessary in a 924 or 931.
You can buy a 48-3 battery from WalMart with good power reserves, and a good warranty for $65 (you can buy three for the price of one Optima).
dash16
PostPosted: Fri Jul 24, 2009 12:33 am    Post subject: Reply with quote
I actually have an optima laying around with 800cca and 1000ca.
Is this too much for our cars?
My previous battery that died had 550cca and 750ca.
Im hoping that i don't need a new battery and just use this one but I don't really know how the different cranking amps affect our electrical systems, and am worried about adverse effects from long term usage.
STUTTGART PREVAILS
PostPosted: Fri Jul 24, 2009 2:29 am    Post subject: Reply with quote
No problem there. It's the amperage draw of the cars' electrical components that determine how much "juice" flows. Think of the cca and ca ratings as a capacity, amount, or volume - it just sits there in the battery as a volume of power that's available for use. It's wholy contained and won't bother you or your car until some electrical component is switched on, then only the amount required by that device is drawn from the battery. You could use a 2000+ ca battery if you could find one. The important spec for preserving your electrical system is the voltage, so as long as it's a "12V" battery you're safe.
I have a similar one made by Exide, and mounted it sideways to clear the hood. It's also spiral wound dry cell technology.
The hold-down has been updated since this pic, but it's mounted in the same position-orientation -
dash16
PostPosted: Fri Jul 24, 2009 5:30 am    Post subject: Reply with quote
Looks like I have to mount my optima redtop sideways to clear the hood as well.
Can you please snap a picture of your upgraded mounting so I can get an idea of how Im going to do mine
is that a piece of wood underneath the battery? its safe?
STUTTGART PREVAILS
dash16
PostPosted: Sat Aug 08, 2009 5:18 pm    Post subject: Reply with quote
so i tried to install the optima battery and it turns out that the terminals are too big on the battery!
can someone recommend a battery that fits the following criteria:
1. dry cell sealed
2. fits in the stock battery mounting location and secured by the stock
3. short enough to fit underneath the hood
4. fits the terminals
thank you
STUTTGART PREVAILS
PostPosted: Sun Aug 09, 2009 8:45 am    Post subject: Reply with quote
Are you sure?
I usually find I have to pry open the clamps at the wire ends to fit over new battery posts.
dash16
PostPosted: Mon Aug 10, 2009 1:27 pm    Post subject: Reply with quote
I have yet to try to pry the terminals open but...
I bought a group48 interstate battery and it fit over the posts perfectly. I returned it because it was leaking and I also had a spare optima laying around, so I figured why not use it.
The previous battery was a die hard and it was also a group 48 battery, which also fit over the posts perfectly.
Its my understanding that group 48 is for german cars due to the fact that the logo is a german flag, and so I was also told this by a mechanic.
STUTTGART PREVAILS
