ideason straightening poly...
924guy
PostPosted: Mon Oct 27, 2008 9:19 am    Post subject: ideason straightening poly... Reply with quote
hey all,
any ideas on how to straighten polyurethane spoilers? I pulled this one off the frankenporsche, pretty beat up. I figure i can mend the tears with an epoxy, but not sure how to go about straightening the deformities..
all i think of so far is running a metal backing on one side, and applying heat to the other?
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
Martijnus
PostPosted: Mon Oct 27, 2008 10:21 am    Post subject: Reply with quote
my first thought would be heat... but I guess you can screw it up quite easily that way.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
968rz
PostPosted: Mon Oct 27, 2008 10:51 am    Post subject: Reply with quote
Heat would be my solution also. But not from a flame use a heat gun and maybe some stiff metal to make braces to hold it while it cools.
Rick
Vince Ponz
PostPosted: Mon Oct 27, 2008 11:50 pm    Post subject: Reply with quote
Use a hair dryer first. Then a heat gun. Go slowly or you will blister the piece.
Maybe you should mount the valance first to see how much of a curve you have. Then use heat.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PORSCHEV
PostPosted: Tue Oct 28, 2008 1:31 am    Post subject: Reply with quote
This is how I have successfully fixed dents and defeats in Poly urathane parts. have some pieces of wood cut that you can clamp the area straight with. Once you have the part ready to be clamped you heat the area FIRST with the hot setting of the heat gun. get it as hot as possible without blistering. Then clamp it straight. Cool it with a water soaked cloth.
You may have to hyper extend the dented area to over come the spring back effect the damaged area with being suffering with.
1978-#53 "D" track racer.
