Anyone seen this pipe before?
Sy924
PostPosted: Thu May 14, 2009 4:26 am    Post subject: Anyone seen this pipe before? Reply with quote
Anyone with a 924S taken their PAS system apart?
I'm after a replacement on of these:
http://i581.photobucket.com/albums/ss257/sy355/2009-05-10-924S-Repair-013r.jpg
But the manuals seem to list only these:
http://i581.photobucket.com/albums/ss257/sy355/2009-05-10-924S-Repair-008r.jpg
which I think is for a 944 (and looks like there isn't the clearance to fit behind my 924S wing)
(Oh, and it's the power steering fluid cooling pipe, that runs back into the PAS reservoir if anyone's interested)
Any help in part identification appreciated.
Sy
John_AZ
PostPosted: Thu May 14, 2009 7:08 am    Post subject: Reply with quote
I'm guessing you have a 1986 924S and the Porsche factory was still trying to use up power steering hoses from earlier 924s.
If the local parts houses or warehouse cannot help go to a hydraulic shop and they will put on new rubber hose and fittings/clamps. If the metal has cracks or cannot be repaired you might have to try and use the current part number.
GL
John_AZ
1988 924S + 1987 924S
1979 924 + 1977.5 924 +++=== gone, past tutors
Sy924
PostPosted: Fri May 15, 2009 6:51 am    Post subject: Reply with quote
Thanks for the reply - seems the links don't work, I'll try again:
(this's what came off my 924S)
(this's exactly the same as the 924S manual depicts, but appears to be a 944 part)
Ian924s88
PostPosted: Sat May 16, 2009 2:52 am    Post subject: Reply with quote
1988 Blue 924s
Ian924s88
PostPosted: Sat May 16, 2009 2:54 am    Post subject: Reply with quote
opps last post no work. Also get yourself a new updated PS line. This is the one that goes from the resvour directly to the pump. It's shorter and more direct, and doesn't kink like the orginal one. My pump was screaming noises on first startup, all fixed now.
http://www.rennbay.com/updated-power-steering-pickup-line-p-143.html?osCsid=b9bbad186ea27f986e67e9eadc6e0699
1988 Blue 924s
Sy924
PostPosted: Tue May 19, 2009 6:20 am    Post subject: Reply with quote
Thanks for the reply - well it turns out that the 924S manual is wrong! The exploded diagram shows the lower pic with 4 loops (which is actually for some 944s I think) but Porsche's replacement part is the same as what I removed from my car (with only 2 loops).
Not sure what the link is actually selling - I thought the pipe needs the kinks in as that's what actually cools the PAS fluid?
derg
PostPosted: Sun Aug 16, 2009 6:10 pm    Post subject: manual reliability Reply with quote
Yep, our 1988 RHD 924S has same pipe with same corrosion.
"there are more stars in the sky than grains of sand on this planet"
