Rob the plumber
Joined: 25 Aug 2008 Posts: 122 Location: Utica, Michigan
Posted: Thu Oct 16, 2008 3:28 am Post subject: Rear flares |
Where is the best place to buy them, and how eay are they to install.
I saw a few pics of 924's with the rear flares and I like them a lot. I think I saw them somewhere for about $300 a set. _________________ 1981 931 |
Posted: Thu Oct 16, 2008 4:57 am Post subject: |
There are several styles to select from, and three major vendors here in the U.S.:
GTR/GTS (IMSA) style boxed wide bodies -> GT Racing
Holbert style wide bodies -> AIR and IFC
Standard 944 arches -> all of the above
Carrera GT style -> all of the above
D-Prod style -> AIR and GT Racing
I predict you're gonna like the D-prods...  _________________ erstwhile owner of just about every 924 variant ever made |
Splineless
Posted: Thu Oct 16, 2008 3:39 pm Post subject: |
Any opinion as to which is the better made - does it all come down to the installer? I've read differing opinions of the IFC kit. _________________ Porsche 924 - 1978 Metallic copper over brown, changing to black. Custom black and brown leather seat covers.
Weissach-style wheels, 200 lb. coils, thicker roll bars, but bog stock engine. (It's on my list.) |
Posted: Thu Oct 16, 2008 9:26 pm Post subject: |
I own fiberglass panels from GT Racing, AIR and Lindsey Racing. By far, the AIR panels are the best quality of the bunch. I've never seen IFC work up close, so I can't comment. It might be worth pinging one of the Leano brothers who bought that louvered monster in SoCal a while ago. It had an IFC kit on it. _________________ erstwhile owner of just about every 924 variant ever made |
Rob the plumber
Posted: Fri Oct 17, 2008 12:12 am Post subject: |
You should give me a set of your flares. That would be the nice thing to do.  _________________ 1981 931 |
Vince Ponz
Posted: Fri Oct 17, 2008 12:58 am Post subject: |
Okay so you put on the flares. Then you want wider tires. Sorry if you did not cut the original body up about 3 inches. I cut mine then welded the inner wheel well up to meet the outer fender. I two part epoxied them on and also put in screws to keep everything in place. This is not for the faint of heart. As for the screws I drilled holes on the outer part of the flares and left the two inch tab alone. After bolted them on I filled in the outer holes.
Measure twice, no three times and them cut the metal. Mark the car with the flares in place to remind you where to glue them on. It sounds easy but then it is very difficult to correct.
I have said it before in previous posts. I laid in some additional fiber glass to the insides of the flares for strength. You can never be too careful. You don't want someone lean on them and crack them. Best hint....................when you mount them do not stress them to make them fit. They will crack. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Posted: Fri Oct 17, 2008 1:45 am Post subject: |
| Rob the plumber wrote: | You should give me a set of your flares. That would be the nice thing to do.  |
I have the original crappy rear quarters that came with the UWB project, and I have a new but slightly damaged GTR style front valance which are all available for CHEAP (but not free). Just to clarify, I do NOT have flares from all three vendors, but I do have individual parts from all three. _________________ erstwhile owner of just about every 924 variant ever made |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Thu Oct 23, 2008 4:30 am Post subject: |
ideola pm sent _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Maybe924
Joined: 14 Aug 2007 Posts: 412 Location: New London, CT
Posted: Thu Oct 23, 2008 6:07 am Post subject: |
I can attest to AIR's quality, very good fiberglass workmanship. I just ordered a FG hood from AIR also. _________________ 1981 931 GT (CGT Intercooled)
1985 911 Targa Carrera (Sold) |
