Vertical play on rear wheels
Dutch924-racer
PostPosted: Mon Oct 27, 2008 4:21 am    Post subject: Vertical play on rear wheels Reply with quote
I have got vertical play on the rears wheels.
I usume if it where worn bearings I would have horizontal play as well ?
What could it be ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Mon Oct 27, 2008 8:05 am    Post subject: Reply with quote
Yes, you would... so perhaps a suspension alignment bolt has come loose, or a shock mounting, or something like that?
I use a paint pen to mark all the bolts on my suspension, so it's easy to see if they've come loose...
PostPosted: Mon Oct 27, 2008 1:43 pm    Post subject: Reply with quote
Safety wire is usually a better solution for that but using the paint marks isn't a bad idea as well.
Rich H
PostPosted: Mon Oct 27, 2008 8:08 pm    Post subject: Reply with quote
Cehck see what is movign, if its just the stub then its bearings, if its the control arm its a loose bolt if its the spring plate you have torsion bar issues.
PostPosted: Mon Oct 27, 2008 9:18 pm    Post subject: Reply with quote
You took the red pill again didnt you?
PostPosted: Mon Oct 27, 2008 10:08 pm    Post subject: Reply with quote
Safety wire or loctite (we use both, depending on application) are to keep things from moving. Paint allows us to perform a quick visual check on every bolt in sight when a wheel is off, without having to even grab a single wrench.
Rich H
PostPosted: Mon Oct 27, 2008 10:23 pm    Post subject: Reply with quote
Nope, I think that is the problem.
PostPosted: Tue Oct 28, 2008 4:54 am    Post subject: Reply with quote
Yeah, nutting and bolting a race car (especially a door slammer) is a pretty boring job.
Martijnus
PostPosted: Tue Oct 28, 2008 10:43 am    Post subject: Reply with quote
so what would happen if you took both pills...would you get in some kind of limbo?
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Rich H
PostPosted: Tue Oct 28, 2008 6:16 pm    Post subject: Reply with quote
I buy another car...
