bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sat Dec 12, 2009 1:33 am Post subject: Is there room for a power antenna in the fender? |
I want to put a power antenna on my 931. Does anyone know if there's room back there before I take the fender off? _________________ '80 924 Turbo - SOLD!
Porscheless  |
Posted: Sat Dec 12, 2009 1:47 am Post subject: |
Many of the cars came stock with a power antenna. You can get the Hirschman's OE version all day long on eBay. Here's a related thread:
http://www.924board.org/viewtopic.php?t=25217
Also, here's a good thread on how to remove the fender without damaging it. You don't have to remove it to get to the antenna, but you will have to remove the charcoal cannister for sure. Removing the fender is optional, might make the job easier, but adds some steps to the process, your choice:
http://www.924board.org/viewtopic.php?t=20669
Now, before you go to all that trouble, why not consider what 924guy did on his car? I liked this so much I copied it on one of mine. Haven't gotten around to it on the other cars (none of 'em have stereos worth listening to...I enjoy listening to the motor more than the radio anyway!), but I LOVE the way these look when installed:
http://www.924board.org/viewtopic.php?t=15069
 _________________ erstwhile owner of just about every 924 variant ever made |
bnoon
Posted: Sat Dec 12, 2009 2:05 am Post subject: |
Wow, didn't know it was such a pain in the ass to pull the fenders off, won't be doing that. Thanks for the other links. Not sure I want the little roof antenna. Not that it doesn't look great, but I don't want to have to patch a hole in the fender to do it. _________________ '80 924 Turbo - SOLD!
Porscheless  |
Buwani 931
Joined: 31 May 2004 Posts: 308 Location: Napa California
Posted: Sat Dec 12, 2009 7:26 am Post subject: |
Dont worry about having to remove the fender. Jack it up, remove tire and canister and antenna removal and replacement is fairly easy without having to remove fender. I think I even recall doing it by just turning wheel inward , still room.
Shawn _________________ 1980 931
That's thirty minutes away. I'll be there in ten. |
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Tue Dec 15, 2009 12:39 am Post subject: |
I put an elec ant from a Dodge Dynasty in my 924. I didn't have to remove the fender OR tire but did have to adapt the top nut to fit the fender curve _________________ Rick
93 968 coupe Amazon Green 4spd Tip (my DD) |
924guy
Posted: Sun Dec 20, 2009 10:18 pm Post subject: |
plenty of room for most every aftermarket power antennae in the fender. i put a cheapo jc whitney model in my 78 years ago, thing is the size of a brick... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Mon Dec 21, 2009 3:25 pm Post subject: |
Just replaced the antennae on the DP car. Easy...
1) Turn steering wheel to right
2) undo two nuts on charcoal cannister
3) remove top nut holding existing antennae to top of fender
4) remove existing antennae, insert replacement from below.
5) thread new antennae wire through hole in firewall to radio
6) secure new antennae to fender with hirshmann key and lock nut
7) replace charcoal cannister nuts
turn wheel back straight again...
done |
