HEMBRANT12
Joined: 28 Dec 2007 Posts: 20 Location: Grapevine Texas
Posted: Fri Aug 15, 2008 9:46 am Post subject: Fuel Accumulators???? |
Does anyone know if there are other cars that use the same fuel accumulator or compatible accumulators. I'm getting an NA 80 924 back together and am in the process of rebuilding the fuel lines. The accumulator looks shot, but replacements seem a bit steep, just wondering what my options are. _________________ 1988 Porsche 924S
1970 VW Karmann Ghia
1971 VW Super Beetle
2007 VW Rabbit |
wombat
Joined: 07 Jun 2008 Posts: 422 Location: Melbourne, Australia
Posted: Fri Aug 15, 2008 5:31 pm Post subject: |
three questions
One: did you unscrew the screw on the bottom a little and see if fuel came out? If it does then its stuffed
Two: Do you have 2 accumlators or one? (someone will probably know because of the year but I dont)
Three: how much is steep? _________________ 1977 924 2.0 Auto |
924guy
Posted: Fri Aug 15, 2008 11:25 pm Post subject: |
pretty much screwed if you need new accumulator(s) as far as replacements go, easy to spend several hundred on them and not many alternatives. However,rumor has it certain mercedes accumulators are of similar spec, though not direct, fittings are different. If you swap out the fuel lines id bet something could be cobbled together to work. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
wombat
Posted: Sat Aug 16, 2008 12:20 am Post subject: |
| 924guy wrote: | | pretty much screwed if you need new accumulator(s) as far as replacements go, easy to spend several hundred on them and not many alternatives. However,rumor has it certain mercedes accumulators are of similar spec, though not direct, fittings are different. If you swap out the fuel lines id bet something could be cobbled together to work. |
This woul not supprise me, I have noticed a few other thingss on Mercedes at the self serve wrecking yard that look like they would fir the 924 with little or no mod so maybe this is worth a try. _________________ 1977 924 2.0 Auto |
!tom
Posted: Sat Aug 16, 2008 2:42 am Post subject: |
What about a home-made accumulator? Could you just put a sealed piece of pipe in the fuel line like plumbers do for water supply lines? Seems to me this would do the same thing as an accumulator, but it's easily within the realm of cheap DIY'ers.
To use parts all rated for fuel system use, I could easily imagine a T-fitting, with the base of the T pointing upwards into the bottom of a fuel filter, with the top of the fuel filter capped. The air within the fuel filter would act as a spring to maintain fuel pressure with the pump off. If there's insufficient volume, a 2nd could be used. It's a great use for old fuel filters!
A filter body with the elements removed would be preferable of course. . . _________________ 78 924 NA
5-lug |
Chrenan
Posted: Sat Aug 16, 2008 5:02 am Post subject: |
The accumulator has an internal rubber bladder that holds pressure in the system after shutdown (aids in hot starts) and smooths fuel flow. When the bladder ages and rips, it leaks fuel, hence when you loosen the screw on the bottom of a failed accumulator fuel drips out. Making one may be slightly outside the skills of the average home mechanic. _________________ 1987 951 - M193 Version for Japan |
HEMBRANT12
Posted: Sat Aug 16, 2008 6:04 am Post subject: |
It's definately shot, I took the screw out and fuel ran out for a good 30 seconds. Looks like I'll be getting a new one _________________ 1988 Porsche 924S
2007 VW Rabbit |
michi924
Joined: 22 May 2007 Posts: 163 Location: Pontevedra, Spain
Posted: Sat Aug 16, 2008 6:35 am Post subject: |
Hello Hembrant. I bought one of those at Autohaus Arizona a few weeks ago. Thay had te best price I found in Internet.  _________________ Porsche 924 NA Euro. |
michi924
Posted: Sat Aug 16, 2008 6:36 am Post subject: |
Sorry. I forgot the link:
http://www.autohausaz.com/ _________________ Porsche 924 NA Euro. |
924guy
Posted: Sat Aug 16, 2008 11:01 pm Post subject: |
65.89 and 97.30 depending on return line or not at the above link, excellent prices... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
968rz
Joined: 21 Aug 2006 Posts: 537 Location: S. E. Wisconsin
Posted: Sun Aug 17, 2008 11:25 am Post subject: |
How come mine is $210 ?
0438170024
Bosch
Fuel Accumulator
1 per car. $210.44 _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD) |
datatrain
Joined: 15 Sep 2007 Posts: 441 Location: Osoyoos, British Columbia
Posted: Sun Aug 17, 2008 2:55 pm Post subject: Good prices |
Those guys have excellent prices. Alternators and starters are cheap compared to what I usually see.
Another place I found that has reasonable prices is the PartsBin.com Got a complete exhaust system 183 bucks _________________ '78 924 NA with Collector plate
33 year old car, with me for 21 yrs
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
Posted: Sun Aug 17, 2008 10:23 pm Post subject: |
| 968rz wrote: | How come mine is $210 ?
Fuel accumulators for cars up to 1978 are about $100 then for 1979 onwards the price jumps to around $250. No idea why the jump n price but the AutoHaus Az prices are still amongst the best. _________________ 1979 924 (Gone to a better place)
Posted: Sun Aug 17, 2008 11:32 pm Post subject: |
I agree about Autohaus, but when I must obtain anything from a dealer, I call or email these guys. They usually beat my local guy by 30% or more:
Sunset Porsche phone 1-800-346-0182
attn: Jeff Clark fax 1-503-601-3090
4030 SW 139th way
Beaverton OR 97005
Parts department hours: Pacific Time
Mon-Fri 8-6 Saturday 9-12 (3 hours)
Closed Sunday
secure order form link to place an order:
http://www.sunsetimports.net/sorder.php
Sunset Imports website:
www.sunsetimports.com _________________ White 87 924S "Ghost"
RC
Posted: Mon Aug 18, 2008 12:31 am Post subject: |
| The early 924s have two of 20cc accumulators while the later (79+) have only one 40cc unit. Still no justification for the vast price difference though. |
