body parts.
CorsePerVita
PostPosted: Thu Jul 31, 2008 4:42 am    Post subject: body parts. Reply with quote
ok, so is there anyone who makes fiberglass parts, aftermarket that are the stock form?
looking at the front of the car where the passenger side is damaged it appears that the fenders and bumper are one piece????
once again this is a 77'
(edit) i totally put this in the wrong forum section, please move mods, and my sincere apologies.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
StienbargerR
PostPosted: Thu Jul 31, 2008 5:11 am    Post subject: Reply with quote
It shouldnt be just one part, unless for some reason somebody fiberglassed them together. If you peel the rubber stuff up underneath the headlight (on the header panel) You will see a 10mm body screw which is somewhat tedious to remove, but doable.
Ryan
1978 924 NA
CorsePerVita
PostPosted: Thu Jul 31, 2008 6:35 am    Post subject: Reply with quote
Thanks i'll check it out tonight and see if i can find out. It appeared to be one big piece when i looked at it. It /was/ repainted so it is possible perhaps that they did that when they repainted it to "mold" the body lines together. If that's the case and they ARE separate then i'm going to separate them so i can replace the fender as that would save me a gob of money because that's the only part damaged it would appear.
- 1999 Ducati 900SS
