Posted: Wed Jul 09, 2008 3:01 am Post subject: Clutch died - in the nick of time! |
I've just done a 1100+ mile round trip to the Nurburgring, get back home and in less than 50 miles on the island the clutch died. (Don't gloat, Rasta! )
At first I thought it was just the cable, because it had come apart at the bracket end and come off the at the pedal end.
But, after an eventful tow home from a helpful neighbour (during which the tow rope broke twice! ), it seem to be a little more serious than that.
The release arm lever seems to be jammed about mid-way in its travel. There's about half an inch of slop in it but it won't return to its bottom rest position. There's no evidence of spring pressure...
I'm wondering if the release bearing guide tube has disintegrated (is that possible?). There was definitely an increase in noise from that area on the way back from Germany...
Looks like my next few weekends are spoken for!
BTW: Thanks to Rich H for the very helpful PMs. Ta, Rich! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Rich H
Posted: Wed Jul 09, 2008 3:12 am Post subject: |
No problem
It could be the guide tube, the fork bearings or the spring, or even the fork itself.
Hopefully its just a build up of crud on the guide tube that has snagged the bearing. Take the inspection cover off you should be able to see what it is with a torch. (Torch = flashlight BTW )
You must have been doing laps of the island, isn't it only 10 miles across?
Have you met Pompey Steve? He owns 2 924's and is the treasurer of the UK 924 owners club, now normally this would be a silly question (Your from England, do you know my mate Dave, etc) but there can't be many 924's down that way??? _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Jul 09, 2008 3:24 am Post subject: |
God, I hope the forks are OK! Jesus knows where I'll get replacements from. (The guide tube is available from Euro Car Parts for only about £15 plus tax plus postage.)
The island's a little larger than that! It's about 30 miles end to end (E-W) and 20 miles N-S.
I haven't met Steve yet. Or even seen him in his car, But I'm looking forward to it for when I do. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Rich H
Rich H
Posted: Wed Jul 09, 2008 3:38 am Post subject: |
I don't think it'll be the fork, could eb the spring though. They don't generally go (touch wood!) so they should be available from scrappies.
PorscheApart up here are very good for random bits. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Mon Jul 21, 2008 6:06 pm Post subject: |
Right, got the car going - and without removing the gearbox!
The problem was that the release lever had become loose on its shaft. Over time, it seems to have chewed the splines away and finally slipped, leaving me with no clutch!
Pro temps, I've moved the lever outboard on the shaft slightly, to where there's still a little of the splines left and tightened the clamp nut good and tight.
Don't know how long it'll hold for, but if it starts to slip again I'll have to do the job properly and replace the release shaft...  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Rich H
Posted: Mon Jul 21, 2008 7:02 pm Post subject: |
As its all goosed anyway, a quick visit from Mr Welder will fix it...  _________________ 1994 Lotus Esprit S4 - Work in progress...
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Mon Jul 21, 2008 7:33 pm Post subject: |
Mike that's exactly what happened to mine a few years back, hadn't torn the splines off thankfully but it had worked loose somehow and slipped over them.
Crikey, just thinking to myself I've been to the IoW but it was 20yrs ago this summer! eek! Stayed at Gurnard and did the usual tourist stuff around the island, spent some time fishing for wrasse on Yarmouth pier - lovely old pier that, had planned to do a lot more fishing but two of my rods got trashed on the train when some pleb threw their heavy cases onto them.. _________________ Mars Red '78 Euro 924 n/a
There are two kinds of pedestrians: the quick and the dead. |
Posted: Mon Jul 28, 2008 5:29 pm Post subject: |
Pop back any time! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
