john_brunt
Joined: 07 Sep 2008 Posts: 11 Location: Manchester, UK
Posted: Thu Jan 01, 2009 2:29 am Post subject: 924 anti roll bar / control arms |
| hi i own a 1981 924 auto, the anti roll bar connects to the control arms via a tie rod which fits into a half circle bracket on the side of the control arm. I purchased replacement control arms which i was assured where right for my car. When they arrived i noticed straight away that they did not have the semi circle bracket for the tie rods to pass through. Do the later models have a different way of connecting the anti roll bar to the control arms? The control arms do appear the same other than the aforementioned bracket. Any help would be appreciated. |
Posted: Thu Jan 01, 2009 2:43 am Post subject: |
Old way:
New way:
john_brunt
Posted: Thu Jan 01, 2009 2:54 am Post subject: |
| hi, so on the new way bracket five just bolts to control arm?...also the roll bar is a different shape in the new way, well different to mine anyway...can you tell me if new way is a later model version or just the only way to do it now? can the original control arms not be bought? |
Posted: Thu Jan 01, 2009 3:13 am Post subject: |
The "new way" is, I believe, 82 and up 924 and 944.
In these parts, the old style arms would not be at all difficult to source. I have seen them for $20 or so brand new.
Do a search. . .someone on here has adapted a new style front ARB to an old chassis. The major advantage is that in the new style, a 30mm factory part would be available at the salvage yard, while the largest old style ARB is 23mm. _________________ Toofah King Bad
Posted: Thu Jan 01, 2009 3:15 am Post subject: |
The stabilizer bar and its' mountings were changed at a point during the '82 model year.
Yes, #5 is a molded part that fits the bottom of the control arm.
Also, not shown in the pics are the inner mounts - in the later design they're drop link style mounts.
The earlier control arms with the tabs, if still available, will cost way more - like 4x or 5x or more-x more, than the later version without the tabs.
Most cost efficient would be to try welding on some mounting tabs to the new arms, and reuse your existing bar. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Thu Jan 01, 2009 3:20 am Post subject: |
The second diagram in my second post here shows the late-'82 924 through early 944 front stabilizer bar - http://www.924board.org/viewtopic.php?t=14010 _________________ "..it's made in Germany. You know the Germans always make good stuff."
john_brunt
Posted: Thu Jan 01, 2009 3:21 am Post subject: |
| thanks...i do already have a new arb....which is the same as in the picture...i got off ebay for £10....so if i got the new control arms new arb is there anything else i need...obviusly the brackets (5) in pic...are these available new...thanks guys |
