How should the s2 throttle switch work ?
PostPosted: Wed Oct 29, 2008 6:22 am    Post subject: How should the s2 throttle switch work ? Reply with quote
Hello!
My idling suddenly got a bit high. I could adjust it down with the air screw. But still rough idling and it doesnt adjust itself. So i took out the switch. What readings and when am i supposed to get when i measure it. If iīm right we measured and it worked as it should before this happened. But this was some time ago. As it is now it switches at more than half throttle, isnt it suppose to do that after just 1 degree or something like that. I think we got 0.6ohm after that. Can the problem be related to the switch being contaminated by oil that has worked itself down the shaft after some earlier smokingproblems ?
Maybe924
PostPosted: Wed Oct 29, 2008 7:16 am    Post subject: Reply with quote
A malfunctioning Aux Air Valve could cause this also.
1981 931 GT (CGT Intercooled)
1985 911 Targa Carrera (Sold)
gegge
PostPosted: Thu Oct 30, 2008 7:56 pm    Post subject: Reply with quote
Isnīt the throttle switch just on/off? Then the throttle is closed the switch tells the DITC to control idle by adjusting the timing of the ingition.
Carl Fredrik Torkildsen
PostPosted: Fri Oct 31, 2008 4:47 am    Post subject: Reply with quote
Yes, i know how the system works. But I cant remembre what the ohm reading should be when the witch is open. I remember that i read it here some time ago but i cant find it any more..
PostPosted: Sun Nov 02, 2008 7:19 pm    Post subject: Reply with quote
After cleaning it with all sorts of chemicals it now seems to work after we opened it up. A thing I noticed is that the switch includes a switch at almost full throttle that the ditc never use. Intressting...
PostPosted: Sun Nov 02, 2008 7:34 pm    Post subject: Reply with quote
yea..it has two swithces but it only uses one to find out if its idling or not.
PostPosted: Mon Nov 03, 2008 5:25 am    Post subject: Reply with quote
S2 switch has three outputs, one for idle, one for WOT, and one for partial load.
Terminals and functions are discussed by Keno and others HERE.
When installed, the idle switch should go OFF at one degree of throttle rotation, approximately .2 to .5 mm gap at the throttle stop. Rotate the assembly until this spec is achieved.
PostPosted: Mon Nov 03, 2008 5:42 am    Post subject: Reply with quote
yea...3 terminals but only two wires going to the DITC
