CV joint
andytuks
PostPosted: Sat Jul 12, 2008 6:50 pm    Post subject: CV joint Reply with quote
yo ppl the rear left cv joint is not lined up properly for me, i cant get the bolts to screw in cuz its not lined up.. any suggestions?
PostPosted: Sat Jul 12, 2008 7:07 pm    Post subject: Reply with quote
FBH?
andytuks
PostPosted: Sat Jul 12, 2008 10:22 pm    Post subject: Reply with quote
fbh??
wats that..
im talkin about my left axle cv joint.. is there a way to move the joint around cause all i need is to move it a cm. so i can put the bolts in it..
PostPosted: Sat Jul 12, 2008 11:40 pm    Post subject: Reply with quote
Think he's suggesting a large persuader (hammer).
PostPosted: Sat Jul 12, 2008 11:50 pm    Post subject: Reply with quote
What did you do with the joint? -If it was disassembled, but then not reassembled correctly, it won't flex and won't extend as it should.
wombat
PostPosted: Sun Jul 13, 2008 1:52 am    Post subject: Reply with quote
Ozzie wrote:
FBH?
F**king Big Hammer
is what I think he means
1977 924 2.0 Auto
andytuks
PostPosted: Sun Jul 13, 2008 8:20 am    Post subject: Reply with quote
i only just took it off on the transmission, then hung it so it would not get dirt in it or damage. can the connection point at the trans be moved around? and where would i used a FBH anyway?
356speedster
PostPosted: Sun Jul 13, 2008 8:49 am    Post subject: Reply with quote
Since you have an auto I assume you left it in "Park", but still there can be some play in the gearbox/diff so the mounts on the diff can turn a little. Try turning it, or even better turn the opposite wheel if it is attached and mounted.
What was the reason for taking off the shafts? lowering the gearbox?
1982 Porsche 924 na My 924 blog
1990 Porsche 928 S4 My 928 blog
1995 Fiat barchetta
2007 BMW 318d M-Sport
2010 Volvo V50
Slam
PostPosted: Mon Jul 14, 2008 12:57 pm    Post subject: Reply with quote
Pop a long punch or screwdriver through the CV bolt hole and into the flange on the tranny (or axle) and work the joint back and forth until you can line it up.
Robert, at that point, is your mother's sibling.
Assuming the car's jacked up so you can spin the wheel.
