headlights problem - open when off, closes when on
serz
PostPosted: Mon Jun 16, 2008 7:57 pm    Post subject: headlights problem - open when off, closes when on Reply with quote
So the problem is that it stays open when turned off, and after turning lights on, it coses and enlights under the car
maybe some problem with the button itself - wires conected wrong? Maybe someone has photo of normally working switch?
ex Porsche 924 1978
ex Porsche 924 1982
Now Porsche 924 turbo
http://www.thebestporsche.com
PostPosted: Mon Jun 16, 2008 11:58 pm    Post subject: Reply with quote
This is in the wrong forum. "How-To"'s start with answers, not questions.
-But your headlights are obviously out of sync. I'd switch them off, unplug the connector at the motor, loosen the nut on the motors' shaft and pry off the small linkage arm there, then reposition the headlights to the down position, reattach the linkage, reattach and tighten the nut.
dpw928
PostPosted: Tue Jun 17, 2008 12:07 am    Post subject: Reply with quote
The same thing used to happen on my 80 NA. I could open the hood and tap the connector at the headlight motor and the headlights would retract. The problem was caused by loose/spread female connectors in the plug.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
Scorpio
PostPosted: Sat Jun 28, 2008 6:13 pm    Post subject: Reply with quote
What are the brackets on the rear of the headlights for?
mine are connected to nothing and seam to have no purpose but to make a semi circle sweep for no reason ??
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
dpw928
PostPosted: Sat Jun 28, 2008 9:37 pm    Post subject: Reply with quote
There should be stops on them that hold the headlight steady when in the raised position.
Dennis
81 931 5 sp
78 928 5 sp Silver
Scorpio
PostPosted: Sun Jun 29, 2008 7:29 pm    Post subject: Reply with quote
ah ok..how necessary are they? antone have a piccy of what they look like when up against the stops?
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PostPosted: Mon Jun 30, 2008 12:40 am    Post subject: Reply with quote
Without them the headlights would jump around with every bump.
There is a screw on them with should come against a stop when raised.
Sorry no pics but going to remove my LH one soon- I'l take camera.
