radiator fan @ performanceproducts
Duncan
PostPosted: Sat Jun 28, 2008 7:14 am    Post subject: radiator fan @ performanceproducts Reply with quote
I saw performanceproducts offer a engine cooling fan for only $160,
that seems much more reasonable than the quotes I hear earlier.
Is this the correct one?
http://www.automotion.com/productpage.aspx?cid=11&sid=33&pid=111432
Duncan
PostPosted: Sat Jun 28, 2008 11:33 am    Post subject: Reply with quote
Does your car have one or two? If one, it looks right, and it looks like the fan only, no shroud.
Duncan
PostPosted: Sat Jun 28, 2008 11:42 am    Post subject: Reply with quote
I have one fan, euro car, no AC.
My own fan makes a terrible noise.
Duncan
Chrenan
PostPosted: Sat Jun 28, 2008 11:51 am    Post subject: Reply with quote
I mounted a big aftermarket fan. Cheaper than the factory one, moves more air, covers more of the radiator and uses less amps.
PostPosted: Sat Jun 28, 2008 12:46 pm    Post subject: Reply with quote
Got pics? I was thinking of a custom unit myself.
Chrenan
PostPosted: Sat Jun 28, 2008 12:48 pm    Post subject: Reply with quote
I'll take some and post later tonight.
nesty
PostPosted: Sun Jun 29, 2008 11:26 am    Post subject: Reply with quote
Am I right in that 924 fans play a very major role in cooling?
I took mine out today, only in traffic does the gauge go to creep up but about 75F today in UK & the fan going 10 to the dozen.
I get the impression if my fan wasn't working then I would be in trouble?
Porsche 924 2.0 Litre (1982 model),
Porsche 911, 3.2 Carrera
Chrenan
PostPosted: Sun Jun 29, 2008 2:57 pm    Post subject: Reply with quote
Here you go:
endwrench
PostPosted: Mon Jun 30, 2008 3:04 pm    Post subject: Reply with quote
Simple install of a $50 14" slimline that pulls gobs more air than either the stock single fan or the dual A\C fan I also had mounted at one time. It is mounted to a 951 rad but I see no reason it wouldn't work as well on a 924 rad.
By endwrench at 2007-06-17
Todd
PostPosted: Mon Jun 30, 2008 8:48 pm    Post subject: Reply with quote
I did similar to Endwrench but bought a smaller unit and fitted it to the original cowling.
For the A/C I fitted a 12" on the front of the condensor in a 'push' configuration.
