skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Sun Jun 15, 2008 9:37 am Post subject: Starter won't disengage |
I have replaced the solenoid and it worked fine a couple of times. Now it is back to staying engaged even after the engine starts. I have to pull the battery terminal to make it quit. Does this starter require some shimming that is missing ? _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone) |
Posted: Sun Jun 15, 2008 1:59 pm Post subject: |
Check your ignition switch. _________________ White 87 924S "Ghost"
skytrooper
Posted: Sun Jun 15, 2008 11:29 pm Post subject: |
Well whattya know ! It was cracked at the little pin.
Now I just have to find a switch
Thanks Paul _________________ Matt
1982 - BMW 633CSi
1984 - BMW 528e
skytrooper
Posted: Fri Jun 27, 2008 9:20 am Post subject: |
still a NO-GO in this area. I have replaced the ignition switch and the starter solenoid. I am a little confused on what to try next _________________ Matt
1982 - BMW 633CSi
1984 - BMW 528e
RC
Posted: Fri Jun 27, 2008 11:27 am Post subject: |
| skytrooper wrote: | | still a NO-GO in this area. I have replaced the ignition switch and the starter solenoid. I am a little confused on what to try next |
Hook up a meter to the solenoid coil, #50 IIRC, and see if there is voltage when its running on. 12V (nom) means possible shorted wire loom to starter, faulty switch again, or some feedback/connection on the #50 line.
No voltage to the primary indicates the solenoid is jamming or shorting internally or the arm to the bendix drive is locking up, or similar.
Check all your wiring is correct and not bridged at the solenoid or starter. Especially the terminal and wire to the coil, if wired wrong you will latch the solenoid on with the ignition.
Roger |
tuurbo
Joined: 08 Aug 2007 Posts: 1446 Location: East Windsor, New Jersey
Posted: Fri Jun 27, 2008 11:51 am Post subject: |
It won't hurt to have some insulating grease around the nuts holding the wires in place. _________________ 1980 924 turbo, MSD, Meth. Inj, otherwise stock. |
