ca18det 200sx s13
badlad69er
PostPosted: Sat May 09, 2009 2:26 am    Post subject: ca18det 200sx s13 Reply with quote
is this possible as i have an engine ready but want to know if it is possible and what would need to be done i.e keep my torque tube and the rear mounted gearbox and the rear diff or would i need to use the ones of the 200sx??? any help would be appreciated!
1982 - 924 Lux
Next Mods - Carrera GT Kit, 944 Turbo Wheels, 5 Lug Conversion.
Engine Mod to be Done - Install a Nissan 200SX Engine (last job not for anthoer year or two)
tuurbo
PostPosted: Sat May 09, 2009 6:14 am    Post subject: Reply with quote
Quote:
ca18det 200sx s13
What the hell is that?
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
Bumblebee77
PostPosted: Sat May 09, 2009 7:08 am    Post subject: Reply with quote
You guys in the states would call it Sylvia maybe. The S13 was about 89-ish. The CA18DET was the engine from the 1.8 litre turbo version, the "K's". I guess it would fit... its like all the guys in here say "anything's possible with time, money and engineering expertise." Your problem would likely be mating it to the transmission.
77 NA 924
Hopefully one day a little sleeper... although at this point i'll settle for the bloody thing to start...
View user's profile Send private message AIM Address MSN Messenger
badlad69er
PostPosted: Sat May 09, 2009 7:55 pm    Post subject: Reply with quote
how would i go about connecting it up to the gearbox??
1982 - 924 Lux
924guy
PostPosted: Sat May 09, 2009 10:45 pm    Post subject: Reply with quote
nissan engine, 200sx variety , i dont think it ever made it to the states though, but not sure. no idea if itll physically fit, but certainly not a bolt in installation. like any engine swap, especially when changing manufacturers, easy doesn't factor, and deep pockets, high mechanical aptitude, and allot of work is required...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Mon May 11, 2009 8:07 pm    Post subject: Reply with quote
Nice engine the CA18det - all alloy and a lot lighter than the 924 lump and revs like a real sportscar engine.
The usual problems; engine height, engine mounts and modifying the CA18 bellhousing to bolt to the torque tube. The matching gearboxes all seem to have a very long bellhousing so you'd need to slice the bellhousing and weld a plate over the end to bolt to the torque tube.
I've been thinking about that engine in a 924 for some time now.
