What's the part number of this fuel pump check valve???
michi924
PostPosted: Mon Jun 09, 2008 8:12 am    Post subject: What's the part number of this fuel pump check valve??? Reply with quote
Hello. I've been looking for this check valve on the internet (the one in the red box). I've found it in the pet, and i got a part number, but when looking for it on the internet i found that this part number correspond to the other check valve (the one with the holes).
Do you know where can i find the check valve?
Porsche 924 NA Euro.
PostPosted: Mon Jun 09, 2008 8:27 am    Post subject: Reply with quote
#1 is not a check valve - it's just an adapter.
#5 is a check valve (though there are identical-looking adapters available without the check valve mechanism).
#2, the long-neck pump at right has a built-in check valve, and doesn't need an external check valve.
#6, the other pump at left, does not have a built-in check valve and requires an external one.
Which type of pump do you have?
Buwani 931
PostPosted: Mon Jun 09, 2008 9:29 am    Post subject: Reply with quote
Heres a link to a Porsche bulletin thanks to Kevin Gross
http://www.connact.com/~kgross/FAQ/tb/tb.20.8002.html
I got one from Autohaus Arizona
http://www.autohausaz.com/
Shawn
That's thirty minutes away. I'll be there in ten.
michi924
PostPosted: Mon Jun 09, 2008 8:12 pm    Post subject: Reply with quote
Thank you Smoothie and Buwani. This is my fuel pump, it's the long neck type. I've realized that it has a banjo fitting. The only thing i have to do is install the check valve (one not in the red box) between the banjo fitting and the fuel pump, as the technical bulletin says. Right??
I suposse i don't need to clamp the feed hose from the fuel tank becouse i didn't need to do that when i replaced my leaking fuel accumulator. I thought that replacing the fuel acc. would solve my warm start problems, but it didn't so now i want to put a fuel pump check valve...
PostPosted: Mon Jun 09, 2008 11:27 pm    Post subject: Reply with quote
Aha!, so they make check valves in the straight-through #1 style - good to know..
-But yes, you'd need the #5 banjo type, 810 906 093.
