Unable to slow idle speeed.
datatrain
PostPosted: Sat Jun 07, 2008 12:28 pm    Post subject: Unable to slow idle speeed. Reply with quote
I've been asking various question here for the past couple of weeks. Now I'm not sure I'm winning or losing.
I had problems getting the air inlet boots to fit properly and that's now okay. But after getting it all together the idle speed is above 1150 rpm. Even with the idle screw fully closed it's the same. Also I'm getting severe pinging or rattling under load.
I checked all the vacuum connections and there is nothing obvious. But I did have a broken vac. line on the spark advance control a couple of days ago before I started this new project to clean everything up.
Not sure it's relevant but last week put on a new oil filler cap. The old one had a torn gasket and dribbled a trace of oil for 14 years so obviously the EGR system wasn't working perfectly either. I now notice a bit of blue/grey smoke in the exhaust. Smoke which I don't recall before
I'm wondering if the engine had so many out of tune items but it ran well that now I'm fixing things the problems are multiplying.
About 15000 miles back I had new rings and bearings and the valves were quite good so that should not be a problem.
I was driving the car up to 2 days ago and enjoying it.
I'm not quite sure how to get the idle back to 950 any ideas ?
Thnx
DAve
Buwani 931
PostPosted: Sat Jun 07, 2008 12:42 pm    Post subject: Reply with quote
I would think that if you can fully close the idle screw, you have got to be sucking air somewhere. Any hose that has not been replaced is probally due anyway.
Does it do the same hot or cold?
Shawn
That's thirty minutes away. I'll be there in ten.
PostPosted: Sat Jun 07, 2008 12:55 pm    Post subject: Reply with quote
Two items, the AAV and the decel valve bypass the throttle, soooo if either of them are stuck open, idle speed will be uncontrollably high.
leadfoot
PostPosted: Sat Jun 07, 2008 1:24 pm    Post subject: Reply with quote
My guess is your timing is off. Maybe it was advanced to compensate for the leaking air or it has slipped due to a loose lock down plate on the side of the dissy.
Confirm your timing is stock with a timing light on the bell housing inspection hole.
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
datatrain
PostPosted: Sat Jun 07, 2008 2:56 pm    Post subject: Answers to reply's Reply with quote
It does the same hot or cold.
I'll check the decel valve and aux air regulator.
Changing hoses looks to be in my immediate future.
Dist. is tight and could not move.
As I said, it ran fine 2 days ago.
Thnx
DAve
968rz
PostPosted: Sat Jun 07, 2008 11:48 pm    Post subject: Reply with quote
I would check for vac leaks first then check the timing; too much advance would cause this and since you stated the dist is tight and unmoved I would check that the belt didn't jump some how.
And before you think I'm off , Last year my 968 timing belt jumped forward 2 teeth . Never did figure how (I blame wife as she was last to drive it ).
Rick
93 968 coupe Amazon Green 4spd Tip (my DD)
PostPosted: Sun Jun 08, 2008 1:22 am    Post subject: Reply with quote
Youre too far advanced. like 20deg .
Had the same problem with another car.
Get a timing light on it pronto and back to spec.
PostPosted: Sun Jun 08, 2008 1:31 am    Post subject: Reply with quote
You may want to check your throttle stop screw. If the car was running bad, sometimes POs use it to keep the car idling, even though it isn't supposed to be adjusted.
dpw928
PostPosted: Sun Jun 08, 2008 2:54 am    Post subject: Reply with quote
+1 on what Rasta mentioned. Also, the o ring for the idle adjustment screw hs been known to deteriorate and cause a high idle.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
Buwani 931
PostPosted: Sun Jun 08, 2008 3:22 am    Post subject: Reply with quote
I have a question
If it is a timing problem, would you still be able to completly close the idle ( bypass) screw and not have an effect?
Shawn
968rz
PostPosted: Sun Jun 08, 2008 3:37 am    Post subject: Reply with quote
Yes, the idle screw doesn't control all the air, it just routes some past the closed butterflies.
Rick
tom!
PostPosted: Sun Jun 08, 2008 3:49 am    Post subject: Reply with quote
My very high idle went down to normal regions after the CO was adjusted back from 3.5% to 1.3%.
1980 924 2.0, Saturn metallic
