Curious Question: How to make a rev monster?
brealytrent
PostPosted: Sun Sep 29, 2013 9:10 pm    Post subject: Curious Question: How to make a rev monster? Reply with quote
This is more of a ponder than serious question, but what would need to be done to make an early car ('77) with '81 head on it be able to safely rev to something like 7500-8000 rpm and still be streetable? Would it even be possible?
1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Sep 30, 2013 12:56 am    Post subject: Reply with quote
It would need to be precisely balanced, obviously, and need a serious upgrade to the fuel delivery system! Lightening the valve train would probably be beneficial as well.
PostPosted: Mon Sep 30, 2013 1:25 am    Post subject: Reply with quote
Lightened or aluminum flywheel.
Lighter rods and pistons. Possibly even a lightened and/or knife edged crankshaft.
Ported head and higher compression to flow enough air at that RPM
Higher lift cam possibly
Lightweight lifters, which may or may not require stronger valve springs.
Better intake and exhaust (header, side draft carbs or a larger plenum/throttle body)
The lifters are a problem on the street since they require dissasembly of the camshaft to adjust for wear.
Since you'll be pushing the engine pretty hard, a reversed cooling system isn't a bad idea either.
Fifty50Plus
PostPosted: Mon Sep 30, 2013 2:23 am    Post subject: Reply with quote
The stock cam runs out of snuff at around 6000 RPM. It will rev higher but why bother. You will need a better cam profile to have fun in the upper ranges.
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Sat Nov 23, 2013 1:48 pm    Post subject: Reply with quote
This combination ought to get you close:
daniel
PostPosted: Tue Nov 26, 2013 7:58 am    Post subject: Reply with quote
How would the standard bottom end go above 7000rpm?
1989 944 Cabriolet
PostPosted: Tue Nov 26, 2013 8:27 am    Post subject: Reply with quote
I don't think the bottom end is the problem, although lighter rods, pistons, and flywheel would help with freer revving, obviously.
daniel
PostPosted: Wed Nov 27, 2013 8:01 am    Post subject: Reply with quote
So what compression ratio is recommended with the stage 3 cam?
1989 944 Cabriolet
