Reference Sensor
Zermatt924SUK
PostPosted: Sun May 25, 2008 3:36 pm    Post subject: Reference Sensor Reply with quote
Has any Removed or replaced this?
How?
PostPosted: Sun May 25, 2008 9:51 pm    Post subject: Reply with quote
Lots of times....
I assume yours are corroded and will not pull out?
Zermatt924SUK
PostPosted: Mon May 26, 2008 12:56 am    Post subject: Reply with quote
It's For a Fellow S owner....
Having Problems starting While Hot...He has Checked Everything else...Which is fine....So he's assuming it's the Reference Sensor and Yes, he Can't get it Out!
PostPosted: Mon May 26, 2008 1:46 am    Post subject: Reply with quote
They often break off when they will not easily pull out.
How about checking them in place with an oscilloscope?
Sometimes they are cheap on eBay
Mav666
PostPosted: Thu May 29, 2008 7:46 am    Post subject: Reply with quote
Hi Guys, it was me that Zerm was asking for, just not had time to get on here and ask.
Might be a bit hard to ship that OSc. over here to the UK, the rear sensor (B) won't budge the forward one will come up half way but no more, I see that the mount is bolted on with 2 allen key bolts, is there an easy way to get in there and loosen them?
Was hoping I could take the whole lot off and check them that way, then knock the old ones out from the holder while its off the car.
Any help would be appreciated just moved on to the S from an N?A, and it seems like I may have jumped to far!!
PostPosted: Thu May 29, 2008 8:46 am    Post subject: Reply with quote
I suggest you put it back together and find a loaner oscilloscope.
Those allen screws usually strip out while attempting to remove the holder.
I've seen guys break the holder off on purpose.
The sensors are not cheap.....
Mav666
PostPosted: Thu May 29, 2008 9:52 pm    Post subject: Reply with quote
Certainly will look at trying to source one, cheapest I've seen the ref. sensors is around $80 which isn't too bad, just be nice to drive the car and not have to wait for 3 hours til it will start again
Can understand how they would strip if they are steel screwed into alloy.
bcblase
PostPosted: Fri May 30, 2008 12:07 pm    Post subject: Reply with quote
The steel and the alloy do not get along over the long term. It causes the dielectric effect from the dis-similar metals, and corrosion occurs where the metals touch each other. It will usually weaken the threads on the aluminum block.
BC
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
Mav666
PostPosted: Sat May 31, 2008 7:28 am    Post subject: Reply with quote
Guys sorry to have just jumped onto the forum and go straight in with all these Q's but..
I have to use the '24 at the minute to get to work and back, not ideal but then the world isn't made that way
Anyway would a dodgy sensor affect the an automatic cars ability to pull and change gear correctly?
