cgalyon
Joined: 05 May 2008 Posts: 249 Location: Knoxville, TN
Posted: Fri May 23, 2008 8:28 am Post subject: Squeaky belt noise on strong turns |
Today while parallel parking, I heard a very audible squeaking noise, like a loose belt or something. It only happened when I had the wheels turned near the maximum position to get into the parking spot (didn't seem to matter if I was actually moving). As soon as I straightened the wheels a bit, the noise vanished. It wasn't a high pitched squeaking (like metal rubbing metal); more of a rubbery sqeak. I never heard that noise in my 944; it's new to me. I was wondering if anyone has any ideas. Is it a critical noise or just another quirky 924 noise?
Also while I'm at it, anyone have a link to a good set of instructions for changing the coolant? My reservoir is low and while I could just add coolant to it, I figure I may as well see about changing the coolant out while I'm at it (don't actually know the last time it was changed anyway).
Thanks! _________________ 1988 924S Navy Blue - Phone Dials |
Posted: Fri May 23, 2008 11:22 am Post subject: |
Either a loose power steering belt or a noisy pressure relief valve in the power steering pump. _________________ White 87 924S "Ghost"
cgalyon
Posted: Fri May 23, 2008 1:43 pm Post subject: |
Other than the convenience of power steering, are either of those critical to fix? I guess by "critical" I mean will putting the repair off cause damage to other components? _________________ 1988 924S Navy Blue - Phone Dials |
Posted: Sat May 24, 2008 7:37 am Post subject: |
Probably not, but why not at least check your power steering belt's condition and tension? _________________ White 87 924S "Ghost"
