Bumblebee77
Posted: Thu May 29, 2008 6:29 pm Post subject: Brake upgrade on 77 924 NA |
Hey all. I'm pretty sure after some basic research that in order to do a brake upgrade on my car first the wheels need to be upgraded from 4 bolt to 5 bolt.
My question is hopefully directed more at the aussie peeps in here. Is the brake/wheel upgrade a big time op. Does anyone in here know much about prices in Australia? |
fezza575m
Joined: 06 Aug 2007 Posts: 336 Location: Sunshine coast QLD, Aus
Posted: Thu May 29, 2008 7:23 pm Post subject: |
Just adding to that
Does anyone know of brake upgrades without doing the 5 bolt conversion??? _________________ Red 1977 Porsche 924 CGT...THE MORPH IS COMPLETE  |
Posted: Thu May 29, 2008 7:32 pm Post subject: |
Legally?
No.
5 bolt is the only legal way in Oz and from my friend at Beaurepaires, dont think about spacers either.
Any other conversion requires an engineers cert.
Find a turbo or 944 at the wreckers and get the parts there. _________________ Porsche 924 1984 (UK import) NA
Scorpio
Posted: Thu May 29, 2008 7:33 pm Post subject: |
quite a few aussies have done it, its certainly not as cheap here as say the US.
I was thinking of getting it done as part of my full rebuild then decided against...I distinctly remember one of the more knowledable people on this forum ( forgot who)stating that for street use and for the non-seasoned racer, you wont really notice much of a differnce so long as the rears are kept maintained... I also read an article stating that the 5 stud 931 has a similar breaking force as the 924 drums..ie youll lock your wheels up the same..so it all comes down to what tyres your running.
The major benefits of the break upgrade were(correct me if im wrong)
1)they required less maintenance...ie the drums can sometimes get a spongy feel and need readjusting a lot more frequently...
2)and the disks were alot more efficient at dissipating heat, usefull for those windy mountain roads when you sit on your brake alot, or for track..
3) they fill out the wider flares nicely
4) its easier to find nice 5 bolt wheels _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
Posted: Thu May 29, 2008 11:32 pm Post subject: |
If your going for more power that the stock 125 it migth be an idea, else its just bling. Maybe for the maintanence part. My brakes never fade at the track, even if i drive 1 hour stints. And i have r compund tires that allow lots of brakingforce.. _________________ 1980 924 Turbo
fezza575m
Posted: Fri May 30, 2008 9:25 am Post subject: |
How much can brake pads and fluid come into the performance of your brakes?? _________________ Red 1977 Porsche 924 CGT...THE MORPH IS COMPLETE  |
Mav666
Joined: 16 May 2008 Posts: 47 Location: Newcastle, UK
Posted: Fri May 30, 2008 9:40 am Post subject: |
From what Ozzie has said about things there are a lot more legal issue in Oz than in either the UK or US.
One that sticks in my mind is the illegal use of rubber fuel pipe, so I'd check on the legalities of things first, but agree that looking for an S or '44 so that you can swap everything out in one go is the sensible option. |
!tom
Posted: Fri May 30, 2008 10:21 am Post subject: |
The biggest advantage of disks over drums is the ability to modulate disk brakes.
Inherent to the design of drum brakes which have one wheel cylinder at the top is that one shoe is self-energizing, meaning that once the shoe is touching the drum, the rotational force of the drum causes the shoe to press against the drum harder. This does not happen with disk brakes.
This is what makes disk brakes safer than drum brakes.
Like others have mentioned, the drums work fine, but this is an additional difference between disks and drums.
The only way to get drums to not self-energize is like you see on old motorcycles with drum brakes on the front with one cam per brake shoe. To do this with hydrollic brakes you'd need one wheel cylinder per shoe.
On the 924, the brake shoe towards the front of the car is the self-energizing one. I would expect it to wear faster than the rear shoe, but I haven't looked to see if that happens in practice. _________________ 78 924 NA
5-lug |
Posted: Fri May 30, 2008 2:12 pm Post subject: |
The biggest hassle here is if you have an accident, the car has been modified and no mod plate fitted.
Insurance will wipe you.
My wifes car originally came with no seatbelts.
They were fitted by a PO and I had to remove them because a mod plate was not fitted.
The belts were fitted to the "existing holes' provided by the manufacturer but I could not register the car with them on. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri May 30, 2008 4:50 pm Post subject: |
| Ozzie wrote: | My wifes car originally came with no seatbelts.
The belts were fitted to the "existing holes' provided by the manufacturer but I could not register the car with them on. |
Because it's obviously safer with a certificate than with seat belts.
Bureaucrats!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Fri May 30, 2008 4:55 pm Post subject: |
fluid and pads are critical. Way more importand that the size of your brakes. I run motul rbf600, its a pretty cheap fluid, and it has very high boiling limit. I run Hawk HP plus pads wich works nice, no fade at all. And at a grat price over there. Else then that its important to have the brakes in good shape so the caliper can slide and the brake piston can move as it should... _________________ 1980 924 Turbo
Bumblebee77
Posted: Fri May 30, 2008 6:53 pm Post subject: |
| Thanks all... I think i'll probably just stick with the drums then in that case. I'll just make sure they're in good nick and i use good equipment. |
Scorpio
Posted: Fri May 30, 2008 10:40 pm Post subject: |
| Quote: | The biggest hassle here is if you have an accident, the car has been modified and no mod plate fitted.
Insurance will wipe you. | ]
our biggest obstacle here in aus are the ridiculous mod rules
although i did notice in the RACQ insurance pds it stated that the insurance will be void if an unapproved modification contributes to the accident...
key points...contirbutes to the accident
then again illegal breaks could easily be argued to contribute t almost any sort of accident _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Bumblebee77
Posted: Fri May 30, 2008 11:23 pm Post subject: |
| Yeah good call. I think i'll just give it a miss, maybe upgrade the front discs to a more modern unit and just keep the rear drums in as good nick as possible with good components. |
Vince Ponz
Posted: Sat May 31, 2008 12:48 am Post subject: |
For a long time I tracked my modified car on the track and with the 14 in rims and drums. No problem as long as you keep everthing in good shape.
I ran high temp fluid, metalic pads and adjusted the brakes each time I got home.
I switched to a 944 5 bolt setup and am happy with it and the ability to find Fuchs, phone dials, etc to finish the swap.
So, the only thing I can recommend is keep the brakes in good shape and adjust often. If I am not mistaken Jim Pasha also memtioned this same topic.
As for track use remember these are momentum cars and you have to sort of keep the speed up in turns and use the brakes less. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
