Extended wheels bolts
nesty
PostPosted: Thu May 15, 2008 9:35 am    Post subject: Extended wheels bolts Reply with quote
Hi
I have a set of BBS cross spoke alloys to go on. However need extended wheel bolts does anyone know an outlet that sells them.
Nesty
Porsche 924 2.0 Litre (1982 model),
Porsche 911, 3.2 Carrera
PostPosted: Thu May 15, 2008 11:20 am    Post subject: Reply with quote
How long do you need them?
Porsche used 70mm wheelbolts with the ATS 15" cast BBS lookalike Basketweave wheels.
The only problem is, 70mm wheelbolts are expensive. I think I priced them at about $20 a piece from Porsche years ago. Your best bet would be to see if another 924.org Boardmember has a set for sale. You only need to buy 12 if you use wheel locks (can you believe wheel locks cost less than the damn 70mm wheelbolts?).
PostPosted: Thu May 15, 2008 12:48 pm    Post subject: Reply with quote
If you can use 68mm'ers, this place lists them with the Porsche seat type -
http://www.ecstuning.com/HR/appguides/app_search.cgi?make=&qt=studbolt&model=&thread=14x1.5&submit=Search%21
(scroll down to part number 141568PORSCHE)
PostPosted: Thu May 15, 2008 4:40 pm    Post subject: Reply with quote
Pefa sells them.
i have 100mm bolts on my car since a couple of years now.
http://www.pefa-design.de/
nesty
PostPosted: Thu May 15, 2008 7:28 pm    Post subject: Reply with quote
Hi
Thanks for the replies. I have found a couple of places that sell them. Just got see if now what style of bolts I require. Either Taperhead or Raduis head bolts.
nesty
PostPosted: Sun May 18, 2008 5:53 am    Post subject: Reply with quote
Hi
A stupid question here. Is the 70mm the thread length or the whole bolt length?
PostPosted: Sun May 18, 2008 6:12 am    Post subject: Reply with quote
Thread length unless it's a flathead screw.
78 924 NA
5-lug
