Purpose of Vacuum Amplifier
datatrain
PostPosted: Fri May 16, 2008 5:24 am    Post subject: Purpose of Vacuum Amplifier Reply with quote
I could never figure out what this thing does. Since there is a vacuum tank under the fender why the amplifier and what is it amplifying and for what ?
Dave
PostPosted: Fri May 16, 2008 10:59 am    Post subject: Reply with quote
EGR Valve...
PostPosted: Fri May 16, 2008 11:00 am    Post subject: Reply with quote
The tank under the left front fender is a charcoal tank that is used to recover gasoline fumes.
PostPosted: Fri May 16, 2008 11:22 am    Post subject: Reply with quote
Paul, I think on earlier cars there was a funky vacuum reservoir on the passenger side (or driver side for RHD car). It looks like a bunch of spheres attached all together, and it is in the mirror location as the charcoal cannister. These earlier cars also had the vacuum amplifier, which is the funky cylinder-with-sphere-on-the-end that is usually bolted to the frame rail in the engine compartment.
PostPosted: Fri May 16, 2008 12:12 pm    Post subject: Reply with quote
Yes I had one of those on the 77 I bought new, but the 3 sphere reservoir was mounted beside the battery, but according this site's FAQs, they were also mounted in the right hand fender well....
datatrain
PostPosted: Fri May 16, 2008 12:30 pm    Post subject: Reply with quote
Well your almost correct. The vacuum chamber is on the passenger side and the vac amplifier is near the battery. So what's it do ?
Thnx
DAve
PostPosted: Fri May 16, 2008 12:38 pm    Post subject: Reply with quote
Opens the EGR valve.
datatrain
PostPosted: Fri May 16, 2008 1:54 pm    Post subject: Reply with quote
Thanks.
DAve
PostPosted: Fri May 16, 2008 2:39 pm    Post subject: Reply with quote
Yeah, it doesn't really "amplify".. The part that's called "vacuum amplifier" is more like a vacuum-operated vacuum switch. Together with the reservoir you have something that could -almost- correctly be called "vacuum amplifier", as it provides a source of relatively high vacuum when needed to open the EGR, even when manifold vacuum is low, as in during full throttle or accelleration.
