924er
Joined: 10 Jan 2006 Posts: 339 Location: Los Angeles California
Posted: Wed May 21, 2008 4:55 pm Post subject: a/c dont turn on |
its been garaged for 1 year and i changed the ac belt when i turn the knob nothing happens at all. is there a fuse or something? i remember its always been working and its hot here in cali about 99' F!!!!!!1 _________________ 80' Porsche 924 NA - Slower then a S L O W
86' Porsche 951- New toy |
Posted: Wed May 21, 2008 9:20 pm Post subject: |
There is a pressure switch on the receiver dryer (the small cylinder bolted to the outside of the driver side frame rail just behind the headlight bucket). If your refrigerant pressure is too low, the pressure switch will prevent the system from turning on. Quick check is to remove the two leads to the switch, jumper them together, and then try turning on the system. If the compressor comes on, then you definitely need a recharge. Good time to switch over to R134a.
Of course, there could be lots of other electrical gremlins to chase down, but that would be my first guess. _________________ erstwhile owner of just about every 924 variant ever made |
Scorpio
Posted: Wed May 21, 2008 10:18 pm Post subject: |
Is it an aftermarket/dealer installed unit or a porsche unit? easiest way to tell is look at the wiring going to it.....Generally the aftermarket unit wires use solid colour wires where as the porsche units use largely two colour wires
Just finished ripping my aftermarket unit out, pipe connections have started to rust.
Do you hear the ac blower fan come on? listen under the pass side foot rest area.. Sounds to me like a connection to the blower fan may have come loose...not sure about the location of the fuse, mine was inline taped up to the wiring harness as opposed to being on the fuse panel. _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
924er
Posted: Thu May 22, 2008 9:24 am Post subject: |
i would hear a fan when i turn the knob but nothing would come out of the vents,
it is stock a/c came with the car.....
but im going to check to pressure right now... _________________ 80' Porsche 924 NA - Slower then a S L O W
