What would you buy for water/alcohol injection?
vexed73
PostPosted: Mon May 12, 2008 10:16 pm    Post subject: What would you buy for water/alcohol injection? Reply with quote
If I were to buy a turbosmart Eboost II, What alcohol/water injection kit or setup would you buy?
1982 PORSCHE 931
PostPosted: Mon May 12, 2008 10:34 pm    Post subject: Reply with quote
Here's some alternative for you:
http://www.aquastealth.com/
http://users.frii.com/maphill/wi.html
http://www.snowperformance.net/
http://www.aquamist.co.uk/
DISCLAIMER: I'm not vouching for any of these, just pointing them out as alternatives that are available. Smoothie and tuurbo should chime in on this topic. Smoothie is/was running a home-made setup. Not sure which system tuurbo is using, but I believe it's an off-the-shelf setup.
tuurbo
PostPosted: Mon May 12, 2008 11:56 pm    Post subject: Reply with quote
The alcohol kits are fairly straightforward. I like Devil'sOwn and Snow - never used the DevilsOwn but it seems to be the right controller.
If I had to do it again I might get the variable controller. Also make sure you get an LED to light up or show you when your boost juice is spraying.
Multiple small nozzles might be better than one large nozzle for atomization.
Get a big jug or a jug level indicator or both.
Currently my system turns on the juice early, like 1 PSI just to be safe. I don't really need more unless I'm hoofing it, above 7 PSI.
As it is, I am trying to set up a two stage system, maybe have a WOT switch toss some juice into the stream. Work in progress.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
