Engine strip down woes...
Rich H
PostPosted: Sun Apr 27, 2008 5:56 pm    Post subject: Engine strip down woes... Reply with quote
Guys,
I am stripping down an engine off a '79 and I have a couple of problems:
Firstly I need a new set of standard bearing shells - I have a set of 0.30 oversized but ideally I don't want to grind the crank as it looks ok. Any ideas where to look?
Secondly the crank bolt is seized! I have had an impact air gun on it for ages and I have also had it hot enough to melt the galvanizing off the washer behind the bolt!
Any ideas?
Help!
Rich
PostPosted: Sun Apr 27, 2008 8:12 pm    Post subject: Reply with quote
To loosen the front crank bolt I put a breaker bar and socket on it and rotate the motor clockwise till the breaker bar is against the body.
I remove the coil to dist lead then crank the motor with the starter.
*warning.... you do not want the engine to start with a loose or removed crank bolt.
Rich H
PostPosted: Sun Apr 27, 2008 8:25 pm    Post subject: Reply with quote
Good idea, problem is its not in a car its a spare. I have tried my 3' breaker bar but it won't budge.
PostPosted: Sun Apr 27, 2008 9:14 pm    Post subject: Reply with quote
lock the flywheel with a plate and bolts to the block.
use a 3 ft pipe on the breaker bar
Chrenan
PostPosted: Sun Apr 27, 2008 11:54 pm    Post subject: Reply with quote
I took this approach but locked the flywheel with a piece of angle iron to the engine stand. Worked like a charm.
Rich H
PostPosted: Mon Apr 28, 2008 12:44 am    Post subject: Reply with quote
Will find a bit of angle and a bit of scaff and give it some abuse!
Cheers
Martijnus
PostPosted: Mon Apr 28, 2008 2:39 am    Post subject: Reply with quote
CLICK
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Rich H
PostPosted: Mon Apr 28, 2008 6:47 am    Post subject: Reply with quote
Wow, £125!
PostPosted: Mon Apr 28, 2008 6:01 pm    Post subject: Reply with quote
Give GSF or Euro Car Parts a ring. A set of bearing shells shouldn't be much more than £20!
Rich H
PostPosted: Tue Apr 29, 2008 12:25 am    Post subject: Reply with quote
GSF don't stock them
Waiting for a reply form ECP...
PostPosted: Tue Apr 29, 2008 12:26 am    Post subject: Reply with quote
If you find a source for STD bearings that has them in stock, there are a bunch of other folks here who want them...
Min
PostPosted: Tue Apr 29, 2008 12:33 am    Post subject: Reply with quote
Did you ever end up contacting acl? Since according to their email, they had stock.
Min
PostPosted: Tue Apr 29, 2008 1:07 am    Post subject: Reply with quote
Yep.
Michael Flynn @ ACL wrote:
Daniel,
Very sorry but we no longer offer this main set due to low volume and demand. I did some checking and was unable to find something suitable.
Thanks,
Michael Flynn
ACL Distribution, Inc.
4722 Danvers Drive SE
Grand Rapids, Michigan 49512
Telephone: 616-956-1300 ext 107
email: Michael_Flynn@acl.com.au
Min
PostPosted: Tue Apr 29, 2008 1:40 am    Post subject: Reply with quote
ah that sucks :/
Min
DOCO
PostPosted: Tue Apr 29, 2008 4:52 am    Post subject: Reply with quote
did you get your front dampner bolt off?if not do you still have the head on?if so just take out a spark plug and with piston in the down stroke start stuffing in some 3/8's rope into the sparkplug hole untill ya cant get anymore in now carefully bring up piston towards top dead center the rope will act against the piston and the head,allowing you to apply as much pressure on the bolt,without doing any damage inturnally.you should be able to break it free then.oh make sure you bring it to top the way you want to take out the bolt or it wont lock up.
Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR"
